My GPvR, 1.3 Turbo, yes you got it right ;)
Re: My GPvR
Postby brccrx » Sat Jun 27, 2015 12:16 am
Hey, thats nothing special tbh, just brushed on 2 coats of Zinc primer......but first ive wire brush all the loose rust, acid the surface 2 times to eat up whatever wire brush didnt remove or i wasn't able to get to it, then different acid over it to seal it up, two primer coats, 2 finishing coats, job done for years :)
Now its painted black gloss, Stanley top coat that i found in tractor parts supply place, very durable!
Only one ever build 1.3 turbo Fto, 0.7 bar on stock internals...because your imagination is the only boundary :)
brccrx
FTO is my new religion
Re: My GPvR
Postby Superwofy » Sat Jun 27, 2015 11:43 am
brccrx wrote:Hey, thats nothing special tbh, just brushed on 2 coats of Zinc primer......but first ive wire brush all the loose rust, acid the surface 2 times to eat up whatever wire brush didnt remove or i wasn't able to get to it, then different acid over it to seal it up, two primer coats, 2 finishing coats, job done for years :)
What kind of acid did you use.. phosphoric? Bar for the welding (I can't), it looks like a job doable in the driveway.
Did you make any attempts to tackle the inner chassis rust?
Superwofy
Speed freak
Speed freak
Re: My GPvR
Postby brccrx » Sat Jun 27, 2015 4:03 pm
Phosphoric react with rust and convert it, ive use it the second, other one eats rust to bare metal, i would have to check what is it but just google it if ya like.
This car isnt bad inner chassis rust wise, maybe theres some surface rust somewhere but nothing i would be worry about.....you need cut Your way trough panels and chassis legs to get that sorted if its ever a problem.
Everything has been done with the car supported one side only, enough room to do all that even welding :)
brccrx
Re: My GPvR
Postby Sebastian » Sun Jun 28, 2015 9:49 pm
looking back to the first pics , I just realised I test drove this car a good while back when it was for sale ( in Dunshaughlin ) .
Re: My GPvR
Postby brccrx » Sun Jun 28, 2015 10:09 pm
It was 5 speed tip V6 Mivec at the time, now water/alcohol injected 1.3 turbo with manual 1.6 Mivec gearbox conversion :)
Its a good car in my opinion....
brccrx
Re: My GPvR
Postby brccrx » Thu Jul 02, 2015 1:32 am
Under-sealing continues:
Removed most of the suspension, dropped the petrol tank with filler neck, everything what was im my way is either out or will be so i can get the job done proper.
Driver side was just easy with no surprises....
So everything went easy and i got one coat of primer on it no trouble:
Then i went over the passenger side thinking it will be as easy as....
Bitta rust hidden under the factory joint sealant nothing too bad yet:
Then ive found some rot hidden under the paint work :(
Thanks God it should be easy sorted cutting the bad spots out and welding plates and there no drama inside the door seal too!
brccrx
Re: My GPvR
Postby brccrx » Sat Jul 11, 2015 12:10 am
Time to sort the biatch out :)
Rust cut out:
Patching the holes:
Primed:
More surface rust to sort out :(
Then 1st top coat on the sections that already done:
Then another sections got primed:
Then painted 1st coat over yeah....
Then this happened.....
And guess what?.... more section got primed lol
And obviously top coat lol ;)
Also all the parts that were removed got a new life:
TBC soon :)
brccrx
Re: My GPvR
Postby brccrx » Fri Jul 24, 2015 9:07 am
Some other pics from reassembling the whole rear:
Forgot about these but not a big deal as they were easy done....
All done thanks God!
brccrx
Re: My GPvR
Postby Superwofy » Fri Jul 24, 2015 9:31 pm
Nice work cleaning rust from the rear section ! Probably looks better than it did new :D.
I'll be making a thread of my own since a chassis leg recently fractured, so I either address it now or this frame is gonna be toast soon.
Superwofy
Speed freak
Speed freak
Re: My GPvR
Postby Temeeo » Sat Jul 25, 2015 4:49 pm
Great work Seb, also thanks for keeping us posted and for the pictures! Seeing your posts always makes me to go out and do a bit of work on my own car. :)
99 Mitsubishi FTO GX Manual in Passion Red
Temeeo
Re: My GPvR
Postby Sebastian » Sun Jul 26, 2015 6:46 pm
you must really love what you are doing ! keep it up :ll
Re: My GPvR
Postby CJ » Wed Aug 19, 2015 4:24 pm
This is probably the most thorough FTO undersealing project I've encountered. Ever. Hats off to you for your commitment in prolonging the life of a cat that we see less of on the road as time goes by. I look forward to seeing the finished article.
CJ
Re: My GPvR
Postby brccrx » Thu Aug 20, 2015 10:58 am
Right so, here comes next update :)
First i would like to thanks all of You for the support lads 8)
Now the most important car has pass the NCT with the 1.3 engine in it and all, not without some lill trouble but its road legal :r now :)
Pics from yesterday when attending the NCT centre:
1st attempt:
2nd:
Then it passed at 3rd one:
Behind the bars :mrgreen:
Also car got checked by main dealer again for insurance company lol
In the mean time another member of Mitsi family has visit us so i took a few pics of me together :)
Also finally got to fit my intake air temperature sensor...
And exhaust temperature sensor:
Image[/URL
[URL=http://s1303.photobucket.com/user/brccrx/media/Version%20R%20FTO/IMG_20150809_231351360_zpsyab7rufm.jpg.html]Image
Also shirts arrived:
Two wheels got re done too:
She looks good with white wheels, i think its better than on black ones :)
brccrx
Re: My GPvR
Postby brccrx » Thu Sep 03, 2015 9:38 am
Nearly time to leave for the NCT again and ive spot this:
Didnt take long to get sorted:
Sticking out from the background :)
Failed again....
Very close but still....
Retest booked for Saturday.
brccrx
Re: My GPvR
Postby Superwofy » Sat Sep 12, 2015 11:22 pm
Those bushings you replaced on the upper rear control arm (long dogbone), do you have part numbers for them? The outer on the driver's side makes alot of noise.
Thanks.
Superwofy
Speed freak
Speed freak
Re: My GPvR
Postby brccrx » Thu Sep 24, 2015 10:10 pm
Sory dont have part number, was getting em in bulk from PL, its about 20e piece, quite expensive :evil:
Quick update:
Car is nct'd till 11/16 and taxed as 1.3 :!: for 6 months
Also most important mod arrived today!
Actually its the other way round
brccrx
Re: My GPvR
Postby brccrx » Tue Jan 12, 2016 1:00 am
Not long after ive received the stickers clutch started to slip, few days later gearbox differential bearings gave up on the way home from work...
So i decided to try gearbox with 4.0 final drive and longer gear ratio from 1.3 Colt as it mean to be better for turbo set up.....its fecking not!
Week or two later ive ripped it out again and replaced with another 1.6 Mivec gearbox :)
Doing gearbox replacement Crank shaft seal gearbox side got replaced:
Ive put new clutch kit on it:
Normal starter replaced with planetary drive unit...
More stickers arrived to complete the job :)
Anyone still reading this topic?
brccrx
Re: My GPvR
Postby Temeeo » Wed Jan 13, 2016 9:04 pm
Yup, still reading this Seb! :smt002
Temeeo
Re: My GPvR
Postby goz_83 » Tue Jan 26, 2016 10:53 am
Me too. I stop by every now and again.
Re: My GPvR
Postby mivecrx » Sun Mar 20, 2016 8:53 pm
Nice work on this seb!
Are you using any of Seans engine mounts on V6?, I want to upgrade mine
mivecrx
Re: My GPvR
Postby brccrx » Mon Mar 21, 2016 12:24 am
Yes, red v6 has these on.
brccrx
Re: My GPvR
Postby mivecrx » Mon Mar 21, 2016 1:40 am
brccrx wrote:Yes, red v6 has these on.
Just using on bottom 2 mounts ?
mivecrx
Re: My GPvR
Postby brccrx » Mon Mar 21, 2016 8:43 am
Yes....
brccrx
Re: My GPvR
Postby mivecrx » Thu Apr 07, 2016 2:05 am
brccrx wrote:And maybe carbon wrapped roof? :)
Someone must of been reading your thread or your mind :smt005
https://www.donedeal.ie/cars-for-sale/fto-gpx-mivec-manual-200bhp/11994729
mivecrx
Re: My GPvR
Postby brccrx » Thu Apr 07, 2016 7:39 am
In all fairness that looks class Aidan :smt003
If i wouldnt be buying another car end of this week i would have mine done same way....
brccrx
PreviousNext
Users browsing this forum: No registered users and 3 guests
