Track rod end nut torque
Postby Superwofy » Wed Apr 08, 2015 2:15 pm
Hi guys, another torque question:
I will be replacing a split steering rack boot over the weekend and would like to know the correct torque for the nut that attaches the track rod end. I have the manual at hand and found the relevant page. Unlike other manuals I've seen before, many torque values are given in intervals. The driveshaft nut for example, is given as 196-255 N-m. That's a big interval.
Why are they given like this?
Superwofy
Speed freak
Speed freak
Re: Track rod end nut torque
Postby goz_83 » Wed Apr 08, 2015 7:15 pm
Either it's not that important, or it varies depending on the variant of fto. I vote for the former.
Postby Temeeo » Thu Apr 09, 2015 8:32 pm
There is also page with "standard part/tightening-torque table" before the start of the engine section, so maybe go with that or pick some value in between and make a note of it. :wink:
I'll need to do the same job on my GX, the boots on the steering rack are split and so are the boots on the track rod ends and drop links, have just ordered the parts the other day.
99 Mitsubishi FTO GX Manual in Passion Red
Temeeo
Postby goz_83 » Fri Apr 10, 2015 10:37 am
Temeeo wrote:There is also page with "standard part/tightening-torque table" before the start of the engine section, so maybe go with that or pick some value in between and make a note of it. :wink:
What's Been done with the gpx?
Postby Temeeo » Fri Apr 10, 2015 7:32 pm
Still sitting in my driveway, have only taken small bits out of it so far (or to be exact swap them)
Wouldn't be really taking things like the track rod ends and droplinks out of it as I consider them to be "consumables" - if I go down the road of replacing them and then get the wheel alignment done I might as well use new ones.
Temeeo
Users browsing this forum: Google [Bot] and 3 guests
