Engine knock
Engine knock
Postby Craig33 » Thu Feb 11, 2016 1:03 pm
Hi all fto started to knock two days before m.o.t starts knocking as soon as started and increases with revs. think its rod knock but could it be anything else. Checked spark plugs removed each h.t lead but still there took belt of still there as its middle of month im skint so cant afford a garage any help would be.appreciated
Craig33
Re: Engine knock
Postby mivecrx » Fri Feb 12, 2016 9:44 pm
What belt did you remove?
Could be main end bearings, was it starved of oil? What's the mileage?
mivecrx
Have you seen my FTO tattoo?
Re: Engine knock
Postby Craig33 » Sat Feb 13, 2016 8:52 am
Wasnt starved of oil took the alternater belt off its done 100,000 km tried a fuel cleaner and hi octane petrol now sounds like its a really lpud tappet
Craig33
Re: Engine knock
Postby mivecrx » Sat Feb 13, 2016 11:15 am
Well it's could be, is the noise coming from the head? It could be tappet/ hydraulic lifter noise.
mivecrx
Re: Engine knock
Postby Craig33 » Sat Feb 13, 2016 2:25 pm
Sounds like coming from the top of the rear bank wondered if i get an engine flush and do an oil change
Craig33
Re: Engine knock
Postby mivecrx » Sat Feb 13, 2016 5:57 pm
I wouldn't be a fan of engine flush but some people say they work. I think Brccrx could guide you on best thing to do, maybe remove and clean and adjust valve clearance.
mivecrx
