Engine Mounts
Engine Mounts
Postby Temeeo » Mon Jun 06, 2016 5:34 pm
Is anyone on here using poly engine mounts - mine needs replacing so I'm looking for options. Apparently the following inserts from EVO match FTO:
Lower rear mount: Evo I-III
Lower front mount: Evo IV-VI
Top mounts are both: Evo VII-IX
I was looking at this set http://www.ebay.com/itm/1994-2001-Mitsubishi-FTO-Polyurethane-6A12-Engine-Mount-Slotted-Insert-Set-/201598380926?hash=item2ef0332b7e/ but the part number that suggest that they are for EVO has stopped me from placing the order - have contacted the seller if they are guaranteed to be direct fit.
What are the alternatives??
99 Mitsubishi FTO GX Manual in Passion Red
Temeeo
Re: Engine Mounts
Postby brccrx » Mon Jun 06, 2016 5:37 pm
Theres lad on Mitsipieces that does PU cast engine mounts, he did 2 for red fto and 2 for my blue mirage
Only one ever build 1.3 turbo Fto, 0.7 bar on stock internals...because your imagination is the only boundary :)
brccrx
FTO is my new religion
Re: Engine Mounts
Postby Temeeo » Tue Jun 07, 2016 8:42 am
I remember now, whats the going rate roughly? Is it on exchange basis? This reminds me that I have a friend that does a bit of casting, wish I had a spare set for him to play with.
Temeeo
