As expected - NCT fail
Postby optical illusion » Thu May 06, 2010 10:27 pm
Epic fail in fact. Bad enough to be creating my own hole in the ozone layer.
God almighty, I'll have to eat lettuce for the next while to afford this. Are camskill really the cheapest for parts?
Kace - you mention you got a cheap lambda sensor on ebay for E20, could you send me the link? Anyway, here are my results: :cry:
Low idle:
CO 3.01 vol % - FAIL (above 0.5)
HC 329ppm - PASS (above 0)
High idle:
lambda: 0.82 - FAIL (between 0.97 and 1.03) TOO LOW!!!
CO 6.50 vol % - FAIL (above 0.3)
HC 245ppm - FAIL (above 200)
So basically we are looking at, new cat, new O2 sensor, tps sensor...?
Does anyone have a loan of a cat that passed recently? :cry:
optical illusion
Re: As expected - NCT fail
Postby Sebastian » Thu May 06, 2010 10:34 pm
Who got that new CAT for around 150 eur of a site recently ? you can try that
Postby optical illusion » Thu May 06, 2010 10:35 pm
Hmmm... I dunno... show yourselves!
optical illusion
Postby gt94 » Fri May 07, 2010 3:17 am
johntony and fatboy got them off this site i think
http://www.onlineautomotive.co.uk
gt94
Nothing comes between me and my FTO
Postby CJ » Fri May 07, 2010 8:23 am
Very high CO levels, the engine is getting too much fuel (hows your fuel economy?) if you ask me. I wouldn't expect to see such high levels on an decatted FTO in full working order. Replace the lambda (universal, 4-wire off ebay)and take it from there....
CJ
CJ
Postby johntony » Fri May 07, 2010 1:41 pm
yeah them cats work a treat took a while to heat up
GPvR AREO
johntony
Postby ek9 » Fri May 07, 2010 7:24 pm
I have one of those lambda sensors. Think it was 26 off ebay, You can have it for 20 if you want. I never fitted it as my emission problems were just from a dodgy backbox and it's passed that part of the nct now.
ek9 lover ..that is until I got my fto! :D
ek9
Super unleaded
Super unleaded
Postby optical illusion » Fri May 07, 2010 10:21 pm
You have PM ;)
Thanks CJ, not great, but only recently, in fact, since my exhaust started sounding louder....
optical illusion
Postby optical illusion » Tue Jun 01, 2010 9:19 am
I wonder is going for the NCT again the only way of knowing if the new lambda is working?
Was a b1tch of a job fitting the universal, well Derek nearly hopped it off the wall :)
Wish me luck again on Thurs 8.45!!
optical illusion
Postby Kace » Tue Jun 01, 2010 8:31 pm
Why was it a b1tch of a job then, it just needs to be unscrewed and 4 wires connected ? Was it seized up and difficult to unscrew ?
| Silver 95 GPX Manual | 20 years MIVEC experience |
Postby optical illusion » Tue Jun 01, 2010 8:45 pm
Yes, and very small space to manoeuvre in + feelings of claustrophobia = angry derek :)
optical illusion
Postby Muad_dib77 » Tue Jun 01, 2010 9:18 pm
Fingers crossed!
Image<->FTO-Ireland Shop
Tiomáint sé cosúil go bhfuil tú déanach i gcás maise!
Muad_dib77
Postby optical illusion » Thu Jun 03, 2010 10:14 pm
Wtf like, failed AGAIN!! EXACT same reading second time round?!?
Brand new cat and lambda gone into it!! What do I do now??
Does anyone have Paul Nolans number and does he work Saturdays?
optical illusion
Postby CJ » Thu Jun 03, 2010 10:38 pm
Undertake a diagnostic to see if any sensors are out (esp. TPS), those figures are well high, somethings not right. Did you drive the bejaysus out of the car pre-test?
Pauls no. is 086 2649884, he doesn't work Saturdays.
CJ
CJ
Postby Kace » Thu Jun 03, 2010 10:46 pm
I seem to recall that a failed coolant temperature sensor was the third item that could lead to high emissions.
I bought one of these from Camskill but never fitted as the lambda solved my issue.
Postby optical illusion » Thu Jun 03, 2010 10:56 pm
CJ wrote:Undertake a diagnostic to see if any sensors are out (esp. TPS), those figures are well high, somethings not right. Did you drive the bejaysus out of the car pre-test?
CJ
I did, it hurt my ears, Diputane again too.
Darn.
If this was it Kace would you be willing to sell?
optical illusion
Postby Kace » Fri Jun 04, 2010 3:41 pm
Yes - I still have it fresh in the box and can sell to you as it's definitely one of the things to change for emissions based problems.
You should probably swap back out that CAT and sell it on again after the NCT to recoup some of your cash, given that there is probably nothing wrong with your old one.
:idea: I have an idea - how about we all chip in a few quid to the Club Donations bucket and we buy this new CAT from you. Anyone then that needs to use it for NCTs has a nice brand new one to install and de-install afterwards.
Just a suggestion :idea:
Postby colm_mcm » Fri Jun 04, 2010 8:00 pm
hmmmm.... the last time I lent a cat to someone it came back without its temp sensor and with the bolts cross threaded :|
Haven't seen saiD user on here in A loNg time :lol:
colm_mcm
Postby optical illusion » Sat Jun 05, 2010 6:31 pm
Oh guys, I don't know what to do, I'm at my wits end.
Diagnostics showing absolutely nothing... :cry:
optical illusion
Postby CJ » Sun Jun 06, 2010 10:29 am
Swap the coolant temp sensor and head down to a local mechanic for an emissions check. If its still dumping out high levels then its plan B time...
CJ
CJ
Postby optical illusion » Sun Jun 06, 2010 12:56 pm
PM sent to Kace.
Thanks CJ, plan B sounds scary... :?
optical illusion
Postby CJ » Sun Jun 06, 2010 1:05 pm
optical illusion wrote:plan B sounds scary... :?
I reckon plan B should entail getting a good mechanic on board to troubleshoot further, cross that bridge when the times comes. You'll get it sorted in the end ;)
In the mean time, have a read of this article, its US focused but is an interesting read nonetheless in terms of discussing potential causes of elevated emissions.
http://www.aa1car.com/library/2000/ic60032.htm
CJ
CJ
Postby optical illusion » Sat Jun 26, 2010 10:47 pm
Good news folks, changing the coolant temperature sensor did the trick! Big shout out to Kace who so kindly and promptly sent it to me, and to the octaner that tested it for me today (everyplace in Limerick was quoting me €68 for emissions testing!)
Note to self and others: Buy a CTS, fit and test first before buying a new cat and lambda. :roll:
Test again 29 Aug but should be fine!
optical illusion
Postby Kace » Sun Jun 27, 2010 6:56 am
You're welcome - glad to hear that this seems to have sorted the problem. I haven't read a thread yet where 1 of the items you mention (Lambda, Cat, CTS) hasn't sorted out an emissions problem. Only problem is it's hard to work out which one is actually causing the problem.
Postby optical illusion » Tue Jul 27, 2010 9:39 pm
FINALLY! Third time lucky, it passed, good for another 2 years.
Just barely mind you, they did try their best. Failed first 2 tests, but I reckon it's because it was so busy the car wasn't seen for half and hour so cat had cooled down.
optical illusion
Next
