Emission failure?
Emission failure?
Postby newFTOkid » Tue May 31, 2011 12:38 pm
Hi All
Went for the test yesterday and it went down on emmissions :(
Here are the results :
High Idle
Lambda 1.12 (should be between 0.97 and 1.03)
CO 2.27 (should not be above 0.30)
HC 249 ppm (should not be above 200ppm)
Low idle seems to be fine
Any advise welcome :D What would ye recommend I change first ?
Thanks
newFTOkid
Unleaded
Unleaded
Re: Emission failure?
Postby Dragonheart » Tue May 31, 2011 1:46 pm
Did you put in a bit of Redex before going there and drive it hard in 3rd gear on the way to the centre? Also changing oil and filter helps if it hasn't been done in a while. The lambda readings aren't bad, its the CO2 emissions are pretty high.
Dragonheart
Postby newFTOkid » Tue May 31, 2011 3:19 pm
I didn't use redex but I put some Diptaine in yesterday - seems not to have worked though. I drove it really hard down to the NCT but they didn't test it till nearly half an hour later.
newFTOkid
Unleaded
Unleaded
Postby Danny Kierans » Tue May 31, 2011 3:55 pm
id check for leaks in the ex system.
My new site http://www.turbowizz.com
The Kandy FTO maker. :)
Playstation id= danny-jnr-why
NO-1GR MANUAL 96|NO-2GR TIP 94|NO-3 GPVR MANUAL 97|
Danny Kierans
I'm addicted to my FTO
Postby optical illusion » Tue May 31, 2011 11:12 pm
Read here:
viewtopic.php?f=8&t=11721
Diputane doesn't work if things are already bad. I would suggest changing coolant temp sensor before you go changing exhaust, lambda and cat respectively like I did. :roll:
Even at that I barely passed, the trick I find is try get a late night test and redden it before hand. Cooled down FTOs are a big no no.
optical illusion
Postby Gerry » Wed Jun 01, 2011 2:53 am
In relation to the allowed lambda limits:
I would have thought this reading of 1.12 is very high?
I would try ect, then lambda sensor
Gerry
Postby newFTOkid » Mon Jun 06, 2011 5:14 pm
Gerry wrote:In relation to the allowed lambda limits:
Thanks for the replies :)
Hi Gerry ,Whats the ect ?
newFTOkid
Unleaded
Unleaded
