NCT Today (Failed ....now PASSED)
Re: NCT Today (Failed)
Postby StewyD32 » Mon Jan 23, 2012 3:04 pm
I find them lock nuts more hastle than their worth.
Mine split in two which was my fault as I put too much pressure on it.
One half was right against the alloy and had to go to 19 garages for them to get it off as the other 18 garages lock nut removers would have made crap of the alloy as it was rightly wedged beside the alloy.
So the moral of the story is not to try and kick off the lock nut with the wheel brace if it's too tight :oops: :lol:
Silver 97 Mirage Asti V coupe
Burgundy 95 GR
Silver 95 GPX
StewyD32
Full Throttle Owner!
Postby goz_83 » Mon Jan 23, 2012 5:50 pm
Haha. You must have been in a right mood. I'm gettin my alloys reburbed anyway. I'm at the NCT centre right now. Call me paranoid but I think they've picked my car for scrutiny. Been here 15 minutes and I'm still not Queued on the system. Maybe it's because I'm 25 minutes early? I drove the crap out of her, nice high revving, 2nd and 3rd gear. Put double dose of redX in.
Postby goz_83 » Mon Jan 23, 2012 5:53 pm
Myfeckin FTO wrote:
goz_83 wrote:.....I had the lock nuts removed by the garage. Don't have the unlocking bolt, so I had em all removed after I got a puncture and was unable to remove the wheel, forcing me to drive about 500 meters to a garage...
I did give you the lock nut tool - it was left in the boot - look harder! :lol:
I'm guessing the garage might have misplaced it the first time the tires were changed. I had a good look alright.
Postby goz_83 » Mon Jan 23, 2012 6:54 pm
I'm baffled. Emissions were up 0.03% after all that. Man I'm pissed I have to go back to that kip. So emissions are more or less the same. Assuming I have a decat, it's a simple enough install for a cat I take it? Should I gt a new one, or will a used one be ok?
Postby Gerry » Mon Jan 23, 2012 7:44 pm
Gary, waste of time going to the nct with a dcat.
You need to find out whether u have decat or not and go from there.
FTO will never pass the emissons test with decat, its hard enough to get them thru when thay have a cat.
Sorry to say it but waste of time going to retest if you have decat.
You can fill ur car to the brim with redex and it still wouldnt go thru.
Gerry
Postby Dragonheart » Mon Jan 23, 2012 7:49 pm
Nothing to be baffled about, the problem was obvious from day one regarding emissions and it was pointed out here what it was, you need the cat to pass the NCT!! Sorry to be blunt!
The cat is obvious to see if its there, its got a surface that looks like its weave on it. If its a decat it'll just be a polished pipe, its a simple bolt-on bolt-off job to replace the de-cat with a cat.
Dragonheart
Postby Bernard » Mon Jan 23, 2012 7:50 pm
The other thing is to try and get there just in time.
There's no point reddening the car on the way to the test only to let it cool again for half an hour.
Out of curiosity, what was the engine temperature when it was tested?
Postby StewyD32 » Mon Jan 23, 2012 8:16 pm
Well that was expected! :o
I told you, you could have my CAT for the retest when you failed the first time and you had plenty of time to have a look under your car ya fruit bat.
My CAT is here for you if you need it.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby goz_83 » Mon Jan 23, 2012 8:53 pm
Serves me right for being lazy and not checking. I had a look when I got home and its a decat pipe I have for sure. The car was left there for a good half hour before they started to test it, so it would have been cold. The emissions are low, considering there is no cat on it, so that's something to be grateful about. I can just borrow my brothers cat from the gr, but thanks for the offer Stewy. I won't be switching back to a decat, as I don't think it is worth the hassle of changing it over, even if it is a bolt on/off job. I'm thinking an induction kit will more than make up for any sound, or power lost from using a standard cat. If anyone knows of a cat for sale in Dublin, i'm interested.
Postby StewyD32 » Mon Jan 23, 2012 10:16 pm
goz_83 wrote:If anyone knows of a cat for sale in Dublin, i'm interested.
http://www.donedeal.ie/for-sale/cats/2419356
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby goz_83 » Tue Jan 24, 2012 2:11 am
Speaking of cats....one of my cats went missing for a week before Christmas. When she came home, it meant a visit to the vet, because she was obviously hit my a car. Her pelvis was broken and her tail amputated. The €400+ bill was gladly paid to the vets for doing a great job. However, she got out a week ago and hasn't been seen since. Hopefully she returns again and hopefully without injury.
Oh and the Oil temp was 93 degrees when tested.
Postby goz_83 » Thu Jan 26, 2012 6:30 pm
Got a Cat from Gerry, thanks. Got it installed today. Unfortunately, my Atlas branch has no emissions tester, so I don't know the results, but I am confident it will pass. I may drop up to the finglas branch to get an emissions test. I doubt they will charge if I tell them I got it installed in another branch. €110 in total for the part and fitting. I didn't fit it myself because time is tight and one of the bolts needed to be drilled out. Getting it done for me was well worth it. I think I will stop adding up what I'm spending on the car, as I will probably end up havin a stroke.
Postby goz_83 » Wed Feb 01, 2012 12:40 pm
NCT tonight. 3rd time lucky.
Postby StewyD32 » Wed Feb 01, 2012 1:29 pm
At least you got a cat this time.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby goz_83 » Wed Feb 01, 2012 4:17 pm
Yeah I have a cat now. And the other cat came home a few days ago, unscathed and starving.
Re: NCT Today (PASSED)
Postby goz_83 » Thu Feb 02, 2012 12:43 am
So, when the car was finally brought up for testing, the guy had the car in the far lane testing emissions. After 10 minutes, I get nervous. He then backs the car out of the testing area and my heart slows down. I step away from the window for a minute to wait for my name to be called. No such thing. I look back into the testing area and there is my car in another lane...I have a lump in my throat. After 5 minutes (felt like an hour) the guy brings over a colleague. It was looking bad, because this is what happened the last time. A few more minutes and then they bring over a more senior looking guy. Three of them are poking around the engine bay and revving the car. I see red lights on the monitor. I wanted to run out there and see what was wrong. All sorts went through my head. I was thinking it failed, but was it just the cat, or was it something worse causing emissions. So, the main guy came out to me, I was one of the last people waiting. He apologised for such a long delay and said they couldn't find the correct revs with the equipment, as the engine was running smoother than anything he has ever seen. Good I ask.....Very good he says and hands me my PASS cert. Emissions at 0.20%.
Re: NCT Today (Failed ....now PASSED)
Postby Johnk » Thu Feb 02, 2012 10:28 am
Congrats on the pass man.
metro,micra,escort,sti,fto gpx,fto gx
Johnk
FTO is my new religion
Postby StewyD32 » Thu Feb 02, 2012 12:10 pm
:ll congrats.
The emission results wasn't too bad at all.
Same thing happened to me. Your man had my car for over a half an hour calling everyone over. I like to think they were just admiring it 8).
Burgundy 95 GR
Silver 95 GPX
StewyD32
Postby goz_83 » Thu Feb 02, 2012 12:16 pm
StewyD32 wrote::ll congrats.
Hehehe. Indeed they were. Forget the posrsches, lamborghinis and ferraris passing through....Stewy has just brought his fto inda house. :nwor
Postby holio » Thu Feb 02, 2012 10:44 pm
Thats deadly well done.
Ill trade you my non mivec for yours so you can do the money and nct thing again? :D
No? :(
Please? :cry:
Somebody love me :nwor
The ONLY 95GR in shocking red with these specific faults.
holio
Postby goz_83 » Thu Feb 02, 2012 11:24 pm
holio wrote:Thats deadly well done.
No? :(
Please? :cry:
Sounds like a plan. I'll meet you at nobodies house at 25 past nothing, so we can't make the exchange :)
Postby holio » Thu Feb 02, 2012 11:46 pm
Im gonna hold you to that...
holio
Previous
