Here's my guide from doing them at the weekend:
Changing spark plugs is usually a straight forward job. If you've ever worked on a 4 cylinder car, you'll know that's it's rarely more than a 15 minute job.
Because the FTO uses a transverse mounted V6, the rear bank of cylinders are obscured by the intake manifold.
The Plenum has a number of items bolted to it. These include the throttle butterfly, Variable induction motor, throttle cable adjuster, and various brackets securing the wiring loom.
1) Remove the engine cover. This is secured by some 10mm nuts which can also be undone with a Philips screwdriver.
(it may be a good idea at this early stage to change the easy front 3 plugs, mainly to ensure your plug tool is correct)
2) Unbolt the Variable Induction Motor (pictured below) and unplug the connector at the back left corner of the plenum.
3) Undo the top half of the air filter assembly and loosen the jubilee clip that attaches the air intake hose to the throttle butterfly. remove the pipe and the attached section of the air filter box.
4) Unbolt the brackets for the wiring harnesses that are attached to the plenum. re-attach any removed securing bolts to the plenum, and eliminate the risk of losing them. The throttle butterfly (pictured below) is now ready to be removed.
5) The throttle butterfly is secured by 5 bolts, 4 on the side, and one sneaky one at the back. undo all 5 bolts and the butterfly should move freely around. It's now (finally!) time to take the plenum off.
6) The plenum is secured by a number of bolts. It is bolted to the engine and to 4 brackets at the back of the plenum (pictured above)
The 4 bolts towards the front of the plenum are pretty obvious. Less obvious are the 2 nuts at the corners (highlighted with arrows)
7) The plenum has a tube connected at the back, undo this, and you can remove the plenum. This is done by pulling the plenum straight up. this will reveal the air inlets for the engine. be careful not do drop anything, even dirt, into these inlets.
The spark plugs can be accessed by first unbolting the corresponding coil packs and then pulling out the plug lead.
Changing the plugs themselves is the same as with any car, and the same precautions apply. The OE Mitsubishi spark plug tool has a rubber ring that makes for easy plug removal, and aids correct threading of the plug.
Hope that's some help. I did it in just over an hour.
Denso Irisiums from Camskill are the way to go
