Help ahhhh
Help ahhhh
Postby Angie » Tue Mar 27, 2012 9:03 pm
I was driving my automatic fto yesterday when i indicated the car juddered then the drive light and indicator light went out. Now triptonic doesnt work and it wont change gear. When i try the indicators they still wont work but the neutral light comes on. Any ideas out there???
Angie
Re: Help ahhhh
Postby Bernard » Tue Mar 27, 2012 11:14 pm
Angie, Search the forum for the diagnostic procedure.
It's easy, only takes a couple of minutes and should give you an idea of what's wrong.
Re: Help ahhhh
Postby goz_83 » Wed Mar 28, 2012 12:31 am
Also say hi in the intro area
Re: Help ahhhh
Postby Myfeckin FTO » Wed Mar 28, 2012 9:32 am
Don't think there is any connection between your indicators not working and your Tip box not working. Do all other electrics work fine (windows/stereo/lights etc). Does the FTO start and sound ok? What gear is it stuck in? A bit more info will help narrow down your issue.
Re: Help ahhhh
Postby threediamonds » Thu Mar 29, 2012 4:41 pm
An auld hello wouldnt go amiss.
Dublin- Home of Guinness, Dáil Éireann and square wheels.
threediamonds
Re: Help ahhhh
Postby CJ » Thu Mar 29, 2012 6:39 pm
Angie, welcome to the forums. The problem is likely to be one of two things - either a sensor(s) in the gearbox needs replacing or the torque converter in the box has had its day. If its sensors, a diagnostic check as per Bernard will show it up. Check the colour of the transmission fluid, if its very dark (i.e. black) then its a sign of toque converter failure. Healthy fluid is red, old / boiled fluid is brown. This check isn't definitive but may help in the diagnosis. A bust torque convertor almost always ends up in the owner replacing the gearbox, the work required to replace the TC simply isn't worth it.
