its all came to a head, i am an alcoholic.....last few mths i have been hittin it hard,,,,works went down hill , finances ?-none exisistant . totalling 90 quid a week. fell out with her and flung out ...
reality check. its time to give it a buy before i either am homeless permantely and jobless or i die.....
heads up and dont let it get you . hard times everywhere but you have to be strong . think about those around you !
Often one of the hardest part to solving any probllem is finding the cause of it, you've done that bit so really make the effort give it up. It'll be worth it.
thoughts with you cm75, I respect you being able to even state that its a problem and it has to stop. I hope you get the support from those around you to help you though it mate. good luck.
cheers for the support . been behaving a little . i have managed to cut it back .but the true test begins on mon . when i return to work . coming home and not havin those few beers to un wind..good point . i finally finished my living room
I really do hope this works out for you mate, I've seen drink distroy a few lives. The fact that you can say it out in the open is a huge step. Ususally is stays behind doors, and can be hidden surprisingly well, but this normally just leads to it getting worse. I hope you find that there is support out there when you're able to admit you need help.
And don't look back!
