Modifications
Modifications
Postby ftolam13 » Mon Apr 16, 2007 11:40 pm
hi does any1 know any good Modifications i can mach to my fto engine mods???? and were to get them
ftolam13
FTO is my new religion
Re: Modifications
Postby Myfeckin FTO » Tue Apr 17, 2007 12:09 am
ftolam13 wrote:hi does any1 know any good Modifications i can mach to my fto engine mods???? and were to get them
Depends on budget really - Breather mods are fairly typical - Filter (ITG/HKS etc) or cold Air induction kit, Decat or high flow cats, less restrictive exhaust, manifold and downpipe, uprated fuel pump, fuel pressure regulator and aftermarket ECU can also help, Denso plugs, remove air con (reduces engine load + weight) - if you still have some change then some bored out throttle bodies - theres no end to the money you can spend but to be honest you won't gain a significant amount of power - my advice is to fit an ITG filter and an aftermarket Cat back exhaust and enjoy the sound - any leftover bucks should go on improving suspension and brakes.
Re: Modifications
Postby ftolam13 » Tue Apr 17, 2007 12:15 am
I hav a stainless steal straight through manifold and downpipe. roll cage. mivec controller. front,back and underneath struts. veilside kit. very rare carbon fibre rear lights. 2nd engine hahaha!! de-restricted. im lookin for more POWER do u know were i can get a aftermarket ECU ??????thks
ftolam13
Re: Modifications
Postby Myfeckin FTO » Tue Apr 17, 2007 12:32 am
ftolam13 wrote:I have a stainless steel straight through manifold and downpipe. roll cage. mivec controller. front,back and underneath struts. veilside kit. very rare carbon fibre rear lights. 2nd engine hahaha!! de-restricted. im lookin for more POWER do u know were i can get a aftermarket ECU ??????thks
The aftermarket ECU's are not FTO specific so anything like a Greddy emanage or Apexi unit should suffice - obviously you'll need to get it mapped in somewhere like Westward Engineering (they also supply aftermarket ECU's).
Stick up some pictures of this FTO of yours - sounds quite interesting.
BTW - you won't see any considerable power increases without going down a turbo route - be it an EVO or 2.5l twin turbo galant engine - if you want increased performance start to loose some weight from the car - my last FTO weighted in at 1160kgs (1200 as standard) at its NCT and that was with 1/2 tank of fuel and spare tyre with the rear seats still in (weren't normally in). The best mod for increased performance in an FTO.
Re: Modifications
Postby ftolam13 » Tue Apr 17, 2007 12:43 am
BTW - you won't see any considerable power increases without going down a turbo route - be it an EVO or 2.5l twin turbo galant engine - if you want increased performance start to loose some weight from the car - my last FTO weighted in at 1160kgs (1200 as standard) at its NCT and that was with 1/2 tank of fuel and spare tyre with the rear seats still in (weren't normally in). The best mod for increased performance in an FTO.[/quote]
how do i Stick up some pictures ???????? i hav a bebo page yes i know i know BEBO :?: :? :!: http://lam2006.bebo.com but some pic are up on that :lol:
ftolam13
Postby kevinod » Tue Apr 17, 2007 8:48 am
I put Mongoose downpipes on mine (available from Ricerocket), gave a bit extra torque.
Don't think mffto mentioned heat gaskets? Guys on the UK forum got some made up so they surface every so often. Reduces the temperature in the intake manifold (and thus the air coming into the engine is cooler).
For pics, you can put the address (http://whatever.com/pic.jpg) of the pic between the tokens (no space), or just point to the pics with a link using the url tokens. Just try not to have the pics too big in size!
Postby RussMan » Tue Apr 17, 2007 10:28 am
I drove by you yesterday in Citywest did i not?????
???? - Ferrari F355 Berlinetta
2007 Nissan 350z GT
2004 Nissan 350z GT
1998 Mitsubishi FTO GPvR
1997 Mazda Mx-3
RussMan
Postby kevinod » Tue Apr 17, 2007 10:57 am
RussMan wrote:I drove by you yesterday in Citywest did i not?????
ftolam13 you're asking, right? I spent all yesterday underneath the car (physically) refitting my exhaust & downpipes. Them lifter ramps are your friend, pity I don't have one... never worked so hard lying on the ground! (keep it clean! :wink: )
Postby ftolam13 » Tue Apr 17, 2007 6:31 pm
yea u did :lol: has any1 got the number 4 Westward Engineering plz pm it or post it 8)
ftolam13
Postby CJ » Tue Apr 17, 2007 7:37 pm
ftolam13 wrote: has any1 got the number 4 Westward Engineering plz pm it or post it 8)
0469541622 - ask for Martin.
Note that theres very little in the way of aftermarket ECUs (piggyback or otherwise) that will give you a significant increase in performance (regardless of mods). The only unit that I've come across that can offer potential increases is the Mines ROM (cost is approx 2k without mapping).
As per MfFTO, turbo charging is the way forward if your budget allows. Just remember to get lauch control fitted!
