Hi there,
Took out standard stereo out of fto last night to put in a new one.
Used Standard iso connectors for fitting.
Having a problem! No power... well not enough power apparently to power the stereo. I know the stereo works fine as i've tried it in my own and works good. Any suggestion? The unit requires 12v DC as standard and when plugged in a light appears on the front panel when the face plate is removed so it would appear to get some power.
The previous radio in the car is using a different connector ... non iso connector which works ok.
Any help appreciated?
I plan on using a voltmeter to check that the full 12 v are available.. until then
