CJ wrote:Mustang wrote:Anyone with CAPS, care to look up the mitsi part number for the Lambda sensor -and check the cross compatability -surely it's common to some other model.
Mustang, p/n is MD312191, its specific to the FTO. I'd be inclined to go the universal lambda route.
Did NCT flag high emissions?
Thanks CJ. Yea I'm gonna go with the ebay lambda sensor first, at that sort of money I've nothing to loose. The price of the one on camskill is an outrage
Emissions results as follows:
Low idle pass
High idle
Lambda 0.825 Pass criteria 0.97 to 1.03
CO 6.6 vol% Pass criteria below 0.3%
HC 243ppm Pass criteria below 200ppm
I did take the car for a spirited drive beofre hand and left it running outside while I went in. However the indicated oil temperature was only 86degC, I'm pretty sure it was 110 degC the last time -must check.
