Location of vehicle speed sensor?
Postby CJ » Tue May 09, 2006 6:19 pm
Can someone confirm is the vehicle speed sensor on a tiptronic is located just behind the gearbox filter? I'm finding that the tip box gearchange in D is erratic in that it sometimes will not change up a gear in line with speed, you have to move over to tip mode and manually change up. ECU has been reset, a diagnostic is throwing up error code 24 which equates to the speed sensor. I know that theres input and output speed sensors on the tip box but which one is at fault? (I'm guessing input)
Postby kevinod » Wed May 10, 2006 9:26 am
I'm guessing you've already looked at the workshop manuals?
Postby CJ » Wed May 10, 2006 9:43 am
kevinod wrote:I'm guessing you've already looked at the workshop manuals?
Yeah, I had a quick look through, buts its a bit vauge, I'll have a proper look, I'm sure the info is in there...
Postby kevinod » Wed May 10, 2006 9:52 am
Had a quick browse through it... workshop_1, p 347, vehicle speed sensor connector is number 6 and on the right hand side of the pic.
p 331 has input shaft speed sensor and output speed shaft sensors, little arrows in the diagrams to show which they are.
Postby CJ » Wed May 10, 2006 10:25 am
kevinod wrote:Had a quick browse through it... workshop_1, p 347, vehicle speed sensor connector is number 6 and on the right hand side of the pic.
Nice one kev, I actually remember skimming over that page yesterday, theres so much in the damn manuals! Looks like the VSS might be down the back of the gearbox, nice and accessible, eh? :?
Postby CJ » Wed May 10, 2006 7:22 pm
Guys, I wiped out the air intake and the battery tray to get a look at the VSS, I'm pretty sure its what you see in the pics below:
Postby kevinod » Wed May 10, 2006 11:37 pm
It looks more or less what I expected it to look like. Saw one in a previous car years ago, the rubber bit was accidentally dropped into the gearbox somewhere, couldn't get it back out. Just put a new one in and the old one I guess just got chewed to bits. Didn't seem to do any harm anyway.
So any the wiser now having had it out, still getting that error code I guess?
Postby CJ » Thu May 11, 2006 8:58 am
kevinod wrote:So any the wiser now having had it out, still getting that error code I guess?
I'm leaving it for a day after the reset to see if the error returns, we shall see...
Re: Location of vehicle speed sensor?
Postby deanow1307 » Tue Oct 20, 2009 9:57 pm
Hi, I am new and have just asked this question, the answers are above, I shall try my VSS, I have been told this is the most common problem with speedos not working, will check tomorrow and keep all informed
regards
dean
deanow1307
