Hello Guys
Okay was up at the crack of dawn to work on the FTO.
I changed the stepper motor and disassembled and cleaned prior to fitting in to the GR.
With the air intake stripped off and the battery out to allow for more room and aid in a ECU reset apart from rusted bolts its was a pretty easy job.
But alas the car still seems to be coughing slightly at idle.
I have taken a few videos to support this, any help would be great
https://www.youtube.com/watch?v=47_kIXs ... e=youtu.beand
https://www.youtube.com/watch?v=WLjWZlF ... e=youtu.beI also followed to the best of my knowledge the TPS calibration
With all the above mentioned components removed I attached the multimeter to pins 3 and 4 of the TPS sensor( which were the pins that the value changed on when the throttle was engaged)
I loosened the TPS so it moved freely on the body and reading the multimeter on the below setting
I moved the TPS to the left and the values rose and then to the right and the values started to drop to a point and at the very extreme of the right started to rise again.
So I moved back to the left until I got the lowest value until it started to rise again
The lowest value I could get was 036
I then tightened the TPS back to the body and assembled all other parts.
The car started but the Videos above were taken after the TPS calibration and the slight hunt/cough of the engine is still present.
But on the plus side the engine error code 13 is no longer present.
Again any help, ideas or guidance would be great
Thank you
Wayne
