Condensation, keeps forming in the rear (left) light cluster. Took off the light assembly and replaced all the bulbs as the terminals were corroding. The light assembly does not appear to be damaged in any way, the 'foam rubber' seals on the body of the car seem to be in tact and the four transparent nylon washers all seem to be ok. Refitted the assembly, but the condensation came back. Someone suggested a hole in the seal between the back black plastic moulding and the outer plastic moulding (red, amber, etc). So I removed the assembly again and looked for a damaged seal -no joy. Refitted the assembly again and the condensation is back!
