belt slipped off
belt slipped off
Postby 998cc-keith » Sun Jun 22, 2008 11:24 am
my belt slipped off 2day the one that goes from crank shaft pully yo powersteering pully wat would this have been it did not break belt looks perfect
log on to irelands mitsubishi owners club
www.irishmoc.org
998cc-keith
Postby kevinod » Sun Jun 22, 2008 2:16 pm
It happens to some people, not sure exactly what causes it, maybe pulley with a worn bearing (wobbling), belt not correctly put on first day, or something like that.
Mustang had to replace his belts a few times because of it.
Alternatively it might just have been loose? Is the belt frayed or does it seem fine?
Postby 998cc-keith » Sun Jun 22, 2008 4:51 pm
belt is fine am gonna put it on in work 2moro all my tools are in there does anyone knw were i can get a new belt old one is fine but would rather change it 2 be safe ya knw
www.irishmoc.org
998cc-keith
Postby kevinod » Sun Jun 22, 2008 11:01 pm
You could probably get a replacement belt (Gates make or the like) in any motor store, they seem to include the FTO in their catalogues these days. Alternatively Camskill & Ricerocket should be able to sort you out.
Postby 998cc-keith » Sun Jun 22, 2008 11:23 pm
but it on and it broke and got stuck on the other on and broke that anytone knw were i can get one around ballyfermot
www.irishmoc.org
998cc-keith
Postby Muad_dib77 » Sun Jun 22, 2008 11:25 pm
any motor factors should be able to help you.. just bring what ever bits you have left of your belts with you..
also - do a search on the forum for Belts - you should find a good few posts on it.
Postby Mustang » Mon Jun 23, 2008 9:08 am
The gates part numbers are 4pk948 and 6pk1017. With these part number a motor factor will know what size belt to supply.(Gates or other manufacturer).
The first time the belt came off, was it at low rpm? I am guessing so, as it was not damaged and didn't take the other belt with it. If the belt is comming off at low speed I'd put it down to bad fitment i.e. loose. If it's comming off at high rpm I'd say it's a tensioner/crank pully issue.
According to camskill the crank pully splits in two casusing an imbalance.
For a finish I replaced all belts, tensioners, and the crank pulley.
Mustang
Postby FTOny » Mon Jun 23, 2008 10:06 am
Southside Motor Factors on the Kylemore road have these belts in stock. I changed mine recently. Not expensive either!
FTOny
Octane king
Octane king
Postby 998cc-keith » Mon Jun 23, 2008 6:38 pm
was onto them 2day they said they dont stock them
www.irishmoc.org
998cc-keith
Postby FTOny » Tue Jun 24, 2008 1:46 am
Don't assk them for parts for the FTO, they told me that when I called them too. I brought down both Mitsi & Gates part numbers and he had them on the shelf. I'll dig out the Mitsi parts numbers & post them tomorrow!
FTOny
Octane king
Octane king
Users browsing this forum: Google [Bot] and 6 guests
