If anyone is looking for these in the future
These can be got from companies other than RPW and alot cheaper.
PM me if you are looking for a set as these are custom made
They look well finished dan but I'd replace the button heads with cap screws (provided there's space), they're impossible to tighten enough without damaging them.
On a related note, has anyone come across alloy pulleys (a/c, ps, alt etc) for the FTO? Less unsprung weight on reciprocating ancillary parts has got to be a good thing....
How beneficial would these lighter cams be? presuming the alloy is lighter then OEM, im getting a timing belt done in a month wondering would it b worth my while replacing them? im starting to do minor adjustments , cat / exhaust and if you guys think these will take more strain off the engine i may consider purchasing some.
