Air conditioning unit noise
Postby Mickthepieman » Wed Apr 09, 2008 5:32 pm
I have a ticking noise coming from behind the glove box what can it be ??
it stops after a minute or so.
Mickthepieman
Re: Air conditioning unit noise
Postby Myfeckin FTO » Wed Apr 09, 2008 6:00 pm
Mickthepieman wrote:I have a ticking noise coming from behind the glove box what can it be ??
Is this when the Air Con unit or Heater Fan is on?
Open the bonnet and have a listen on the bulkhead side and see if you can locate more accurately.
Postby Mickthepieman » Wed Apr 09, 2008 6:39 pm
I have just taken out the glove box and the noise is coming from a white plastic box next to the cooling unit. It makes the noise even if the air conditioning unit is on or off.
Thanks for your help.
Mickthepieman
Postby CJ » Wed Apr 09, 2008 8:30 pm
Sounds like the airco fnan, its held in with a few bolts, take it out and it give a good clean (they get full of dust etc). If in doubt, post a pic of the box so as we can confirm.
Postby Phil GPX » Sat Apr 12, 2008 8:19 pm
does it do it when you adjust the temp? or just all the time? like a little buzzing?
Phil GPX
Unleaded
Unleaded
Postby Mickthepieman » Sun Apr 13, 2008 3:44 pm
It only does it when the temp is a minimum if i turn it a above 18.00 it goes away. :? :?
Mickthepieman
