Leaking boot
Leaking boot
Postby StewyD32 » Sat Jan 16, 2010 6:34 pm
hey guys this is an easy one but i don't want to mess it up.
I have water coming in the boot. so much that im thinking of adding fish to it.
I presume (99% sure) that its the lights so i bought silicone so seal it up, so how do you do it.
:oops:
Silver 97 Mirage Asti V coupe
Burgundy 95 GR
Silver 95 GPX
StewyD32
Full Throttle Owner!
Re: Leaking boot
Postby Sebastian » Sat Jan 16, 2010 6:36 pm
do you have a rubber seal around the boot?
I'm not sure it's the lights check it properly!
Re: Leaking boot
Postby StewyD32 » Sat Jan 16, 2010 6:40 pm
yeah seb there is seal around the boot and looks fine. im thinking its the light s as i can see where the water is coming from and its coming from under the lights and the plastic compartments at the side of the boot where the cd changer sits.
I thought it was the arial area as i don't have one but i sealed it up a few days ago so thats not it
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby Sebastian » Sat Jan 16, 2010 7:27 pm
Check the Spoiler as well sometimes if the holes are missing the seals it can leak inside.
I'm finding hard to belive it's the tail lights
Re: Leaking boot
Postby Dragonheart » Sat Jan 16, 2010 7:29 pm
Its not an aftermarket spoiler is it? I'd be inclined to go with Seb and think it was spoiler holes or somewhere around there.
Re: Leaking boot
Postby Sebastian » Sat Jan 16, 2010 7:33 pm
I have a TopMix Spoiler on mine and the hole in the middle (left from standard) it's covered only with a plastic clip , it's not leaking MAD but i can feel a little wet bootcarpet when i check after a heavy rain
Re: Leaking boot
Postby StewyD32 » Sat Jan 16, 2010 7:48 pm
its not an aftermarket spoiler just the standard spoiler, but the carpet and wood setting as dry so it might not be coming from the spoiler. To be on the safe side i'll silicone around the boot seal and check the spoiler, any suggestions on the lights???
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby Sebastian » Sat Jan 16, 2010 7:55 pm
Dont go mad on silliconing the whole boot now :mrgreen:
must be an easy fix , check step by step all the usual leaking points
Re: Leaking boot
Postby StewyD32 » Sat Jan 16, 2010 8:12 pm
lol i woun't. how will i do the lights though with the silicone???
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby colm_mcm » Sat Jan 16, 2010 8:14 pm
it's virtually impossible for it to be the lights.
I'm guessing the car got a smack on the back and there's a leak around the spare wheel footwell. FTOs aren't known for boot leaks and the high boot lip combined with the placement of the light clusters outside of the bodywork (whole unit has to be removed to change bulbs) mean something out of the ordinary is happening.
Water in the boot in some cars can sometimes be caused by water in the cabin working its way back to the boot, leaks from a sunroof etc.
Does your FTO have a sunroof and if so is there any marks on the headlining or is it wet?
Have you checked the condition of the bodywork from underneath?
Re: Leaking boot
Postby StewyD32 » Sat Jan 16, 2010 8:26 pm
colm_mcm wrote:it's virtually impossible for it to be the lights.
There is no sun roof but there is a small crack on the left hand side of the bumper where the crease is on the bumper meets the body so it did have a smack at some stage.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby Dragonheart » Sat Jan 16, 2010 8:39 pm
Would that have dislodged the boot even by a small fraction? Enough for it not to be noticeable to the eye but that it would let water in?
Re: Leaking boot
Postby StewyD32 » Sat Jan 16, 2010 9:19 pm
Dragonheart wrote:Would that have dislodged the boot even by a small fraction? Enough for it not to be noticeable to the eye but that it would let water in?
i just bought it a few days ago so i don't know how bad it was. I'll have a good luck 2moro and silicone everything I can lol :twisted:
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby CJ » Sat Jan 16, 2010 9:29 pm
Remove the rear seat and plastic corrugated section behind the seat, all in, it will take you less than 10mins. Remove the plastic sections behind the lights. Get a torch and have someone hose down the boot while you check for leaks from the back seat.
Re: Leaking boot
Postby optical illusion » Sat Jan 16, 2010 9:58 pm
CJ - never fails to be a wealth of knowledge...
optical illusion
Re: Leaking boot
Postby StewyD32 » Sun Jan 17, 2010 1:16 am
CJ wrote:Remove the rear seat and plastic corrugated section behind the seat, all in, it will take you less than 10mins. Remove the plastic sections behind the lights. Get a torch and have someone hose down the boot while you check for leaks from the back seat.
good idea i'll do that tomorrow before siliconing the hell out of it :mrgreen:
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby StewyD32 » Sun Jan 17, 2010 11:44 pm
ok guys i found the problem
A small hairline crack on the left side below the light. so i siliconed the inside of it..... will i be worth my while taking off the bumper and siliconing the outside???
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby colm_mcm » Sun Jan 17, 2010 11:46 pm
just out of interest Stewy, what colour/year is your FTO?
Prob not worth taking the bumper off. you may be shocked at what you find anyway!
Re: Leaking boot
Postby StewyD32 » Mon Jan 18, 2010 12:25 am
Its a wine coloured 95 gr.
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby Dilogoat86 » Mon Jan 18, 2010 5:47 pm
Haha, I love this guy, he;s silcone mad :) Hope you get it sorted mate :)
Currently in my collection:
'98 Toyota Starlet...
'79 Mini Clubman 1380cc ~100BHP (I hope)
'79 BMW 728
Dilogoat86
Re: Leaking boot
Postby StewyD32 » Mon Jan 18, 2010 6:41 pm
Dilogoat86 wrote:Haha, I love this guy, he;s silcone mad :) Hope you get it sorted mate :)
well i got it siliconed and the boot put back together so im going to wait till it rains and see.
if not i still got some more silicone... best invention ever :mrgreen:
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby Dragonheart » Mon Jan 18, 2010 6:47 pm
It reminds me a bit of Father Ted or something, fixing the car with the hammer.
If you think silicone is great you should try some painter's caulk! That'll blow your mind altogether! :D
Re: Leaking boot
Postby StewyD32 » Thu Jan 28, 2010 7:25 pm
just an update :!:
the boot is water tight and was just a small crack i had to fill in with the silicone :mrgreen:
Burgundy 95 GR
Silver 95 GPX
StewyD32
Re: Leaking boot
Postby Sebastian » Thu Jan 28, 2010 7:35 pm
yea should change your username to SiliconeMan :smt005
Re: Leaking boot
Postby CJ » Fri Jan 29, 2010 9:26 am
Silicone is the new Wavin it would seem!
