New FTO minor problems
Postby sinlessgunner » Mon Feb 11, 2008 10:26 pm
Hi
I didn't know what category to put this under because I have a few problems that need fixing. I bought the car knowing that these things were wrong with it but I want to know are there any quick solutions I can try myself before I pay a mechanic.
1. When the engine is cold I have to keep the car revving slightly to stop it cutting out. When the engine is warm the car is fine. What is the cause of this and how can I fix/prevent it?
2. The rubber bushes in the rear suspension are gone (or so I'm told). I feel every bump in the road. I'll prob get a mechanic to do this but could there be something else causing it?
3. There is a squeakin coming from the engine. I think the fan belt just needs a tightening but could this be something else?
All input greatly appreciated!!
sinlessgunner
Postby CJ » Mon Feb 11, 2008 10:42 pm
1. Stepper motor needs cleaning or replacing - have a search of the forum.
2. Anti roll bar (ARB) bushes and droplinks probably needs to be replaced at a minimum, if you say that you feel every bump on the road, then one or both of the rear shocks may be bottoming out. Solution - replacement.
3. Speaking you say, nest of mice perhaps? ;) Probably just the belts that need tightening.
Check out www.camskill.co.uk for parts info. Depending on your mechanical abilities, you could undertake the arb bushes and droplinks easily. If you're unsure, suggest you speak to a good mechanic.
In the mean time, check out http://www.ftodiy.co.uk/ for mechanical tips.
Postby sinlessgunner » Mon Feb 11, 2008 10:44 pm
Thanks mate. And how much do you think I'd be looking at for the repairs of the suspension?
sinlessgunner
Postby Muad_dib77 » Tue Feb 12, 2008 12:43 am
Cost of parts and prolly a minimum of 50e to fit shock/spring per corner..that's what I've paid in the past anyways.. Might as well get the drop links done as well while you're at it. Make sure to have a look at the bushes as well...
belts are a piddle to change - do a search on the site and you'll find loads of info on it..
Postby kona » Tue Feb 12, 2008 5:56 pm
i have a new unused stepper motor for sale if you need to fit a new one
kona
Postby sinlessgunner » Tue Feb 12, 2008 6:40 pm
Cool Kona. I'm gonna clean mine this evening and if I need a new one I'll give you a shout. How much are you selling it for?
sinlessgunner
Postby kona » Tue Feb 12, 2008 10:31 pm
i will sell it for 110euro, paid 130 for it off camskill,
turned out that i didnt need it.
its for a 2 Litre,dont know if it is the same one for the 1.8
kona
Postby CJ » Tue Feb 12, 2008 10:38 pm
kona wrote:its for a 2 Litre,dont know if it is the same one for the 1.8
Actually, thats just after jogging my memory - I don't think theres a stepper motor on the GS, can anyone confirm?
Postby steelroe » Tue Feb 12, 2008 11:18 pm
Yes there is a stepper motor on the 1.8, but it is different to the 2.0L one
http://www.camskill.co.uk/products.php? ... 0s123p1478
Postby Wildhound » Tue Feb 12, 2008 11:34 pm
He has a GPX though right? Or is this just by-the-way kind of chat.
Wildhound
Postby sinlessgunner » Thu Feb 14, 2008 7:00 pm
Yeah I have a GPX so that would be no problem. Still haven't gotten around to cleaning the thing yet though. Every time I go to do it I just end up taking her out for a spin ha!
sinlessgunner
