Rev Counter failing
Rev Counter failing
Postby sinlessgunner » Thu Jun 11, 2009 1:32 pm
Hey all,
The other day was driving the car and the rev counter dropped to 0 and went back up and now it's happening intermittently. Anyone have any idea what might be the cause. Also, on another note, how often does a timing belt need changing? Mine was last done at around 125k km and there's 171k km on it now. Should I be looking into getting it done?
Thanks!
sinlessgunner
Re: Rev Counter failing
Postby gfalls » Thu Jun 11, 2009 2:04 pm
Stepper motor is the usual culprit..
gfalls
Postby CJ » Thu Jun 11, 2009 3:38 pm
sinlessgunner wrote:The other day was driving the car and the rev counter dropped to 0 and went back up and now it's happening intermittently. Anyone have any idea what might be the cause.
Did engines rev fall with the rev counter? If not, then it could be a faulty spindle or speed de-restrictor. If yes, its the stepper motor (search) as per gfalls.
sinlessgunner wrote:Also, on another note, how often does a timing belt need changing?
Every 100k kms or 5 years.
Postby sinlessgunner » Fri Jun 12, 2009 1:09 pm
Definitly not the stepper motor only fitted a new one about 8 months ago. The engine was fine too it seems to be the spindle (i don't have a de-limiter). How would I go about fixing that??
Oh and thanks CJ for the timing belt info, bit of life in it yet :)
sinlessgunner
Postby CJ » Fri Jun 12, 2009 1:49 pm
sinlessgunner wrote:How would I go about fixing that??
1. Remove the instrument cluster from teh dash and ensure the plugs at the rear are tight in place. Clean up the copper contacts on the rear with a small eraser (see thread re OCD ;))
2. If this doesn't solve it, then the spindle isn't seated correctly. If you've aftermarket dials, this is likely the root cause cause. Handle the spindle with care, try and see if its loose. If so, push it in gently. If you get the impression that its pushed in too far, get a fork from the kitchen and prise the needle cup out ever so slightly.
3. If you're still having a problem then it could be a sensor of some description - undertake a diagnostic (search).
Postby colm_mcm » Fri Jun 12, 2009 1:54 pm
wouldn't be a dodgy ignition fail sensor?
