http://www.customandperformancecarshow.com
Moderators: Moderators, Event Organisers
Myfeckin FTO wrote:Anyone got anymore 1/4 mile tips?
CJ wrote:Myfeckin FTO wrote:Anyone got anymore 1/4 mile tips?
Not a whole lot apart from drop the clutch at high revs and change gears quickly!
Mustang wrote:Check out the post by Daz in this thread
Myfeckin FTO wrote: I'll most certainly strip anything I don't need from the car.
Myfeckin FTO wrote:Erm- I won't be dropping the clutch at anything like high revs - all I'd get is wheelspin - I was thinking somewhere along the lines of 3000-3500RPM to get off the line cleanly - any higher and I'll be stationary with my wheels spinning.
CJ wrote:
If you remove that huge Hiro wing, you should loose a bucket load of weight
....................... is there any industrial parks in your area perchance?
Myfeckin FTO wrote:.........I'll probably stick my FTO into the 1/4 mile..........would be interesting to get a time and see how it stacks up against the Teg type R's - they seemed to rule the FWD roost at last years event.
My best 0-60 was also almost identical to the faster Teg R at 6.48 secs.
Mustang wrote:Some nice results there mfFTO.![]()
MfFTO wroteMy best 0-60 was also almost identical to the faster Teg R at 6.48 secs.
This is impressive, I've seen sub 7 sec times quoted for the FTO and was always a bit sceptical, reassuring to see that these type of figures are achievable.
BTW hows the new clutch holding up
kevinod wrote:Nice one mffto! Sounds good, would have liked to be there.
