a rubbing noise came into the car on Wednesday evening, took a look in the dark & rain but didn't see anything. Looked again when I got home and in the morning (still dark though) but didn't spot where it was rubbing.
Wednesday after work when it was bright, I took a underneath from the front to see if I could spot something, and saw the inside of the tyre had been completely worn away!
Swapped off the wheel and put on the spare. Found it was rubbing off the shock
Now there was no degradation in performance, and handling seemed fine. I'm guessing it must have been rubbing for some time, not hard enough to notice any affect.
Anyone have this problem before? I don't see anything obvious wrong but obviously the hub is either at the wrong angle or something is causing the hub to sit higher than it should be.
Comparing the 2 sides, with the wheel on, there's definitely more space between passenger side wheel & strut than the drivers wheel & strut. Took a few snaps...
Track rod end & around it:
Wishbone:
Driveshaft:
Inside of hub:
