Myfeckin FTO wrote:1: A pully/tensioner on the Power steering/aircon/Alt belt has seized and is burning your belt as it rotates..
2: You have a leak of fluid onto your exhaust - may be a leaky rocker gasket (a squeeze on the bolts maybe enough to stop) or may be another type of fluid or grease reaching the exhaust from a worn part.
jt wrote:Not sure if it's related, but the power delivery is a little inconsistent when I accelerate, so could it be the clutch or gearbox maybe, or a sign that I have a sticky caliper?
CJ wrote:If one of the calipers is seized, the brakes will get very hot - place your hand near (no on!) the brakes after a drive to see if you can ascertain if this is the issue.
