Dave wrote:whilst we're on the topic here, what would happen if you say fit a decent set of spacers to the rear, 25MM and say 10's to the front?
It would really depend on what offset you are currently running.
For example if I put 25mm spacers on my present (correct) offset - the wheels would stick out well beyond the wheel arch and def would rub.
I suppose you could stretch the wheelarch - bodyshop could heat the existing arch and reshape to allow for new offset.
If running 25mm spacers you would have to have the hub adapter type spacer - longer bolts would just not hack it - there would be too much stress. It would also be essential that the spacers would be hubcentric and that the alloy would be correctly located onto the hub.
I would imagine you would likely get handling issues if running different offsets front and rear as well. If its purely for looks though - I would understand it - but I personally wouldn't do it cause I like my car to handle. Your bearings wouldn't last very long in any case - there would still be a much increased amount of stress on them.
