Hi,
Any clue what this box could be?
The labels report some numeric code and a "test" done on 05/98. They are in English not Japanese so I think it's a speedo converter. The hole on the top says "warranty void if removed" and hides a screw, I suppose it is a trimmer to regulate the pulse demultiplier, therefore it affects the speed reading.
My speedometer dial indeed has a label with "MPH" on it wich is simply attached on top of where "KPH" used to be. The fact is, I'd love to have the speedometer reading KPH not MPH.
What do you think? Is it a speedo converter or something else? Should I just play with the screw and see what happens? If I manage to regulate it to KPH, will the derestrictor still work?
Thanks!
