paul2508 wrote:fit a heat sheild and CAI ....ta da...![]()
escu_calin wrote:paul2508 wrote:fit a heat sheild and CAI ....ta da...![]()
what tada.. the idea is to bring cold air inside the engine...
the heat shield does squat if in the engine room is hot.. ~70 degrees at all times you can not shield air from air:)
Bernard wrote:escu_calin wrote:paul2508 wrote:fit a heat sheild and CAI ....ta da...![]()
The idea isn't to shield air from air, it's to shield from radiated heat from the engine itself.
Add to that CAI (properly routed) and you have all the cold air you need.
If the above is set up correctly you get all the benefit of an uprated panel filter plus a nice noise to go with it.
escu_calin wrote:proper setup must have air from in front of the radiator or from outside of the engine bay !
escu_calin wrote:i can not see from the dark picture how the air is delivered from the front to the maf... how is the filter shielded?
stonchy wrote:escu_calin wrote:i can not see from the dark picture how the air is delivered from the front to the maf... how is the filter shielded?
can you not see the hose intake on the right of the reg plate?
escu_calin wrote:stonchy wrote:escu_calin wrote:i can not see from the dark picture how the air is delivered from the front to the maf... how is the filter shielded?
is rude to answer a question with a question; but anyway..
my question is not how the air got to the filter,, but how is delivered and how the cold air is separated by the hot air
i guess this thread is a dead end anyway, because all replays avoid to understand the point
Mitsumaniac wrote:That`s what you need guys... 1 side to the engine, other side to the flexible hose/pipe going outside the engine bay.
I`m with escu_calin ... if you want induction kit - fit it properly, it`s not just about higher air flow but temperature is also important.
Inside this carbon box is one of standard cone filters. About 100 euro without MAF adaptor.
Mitsumaniac wrote:Don`t have them in stock but can get them easily so if there`s interest I can get them to order
Mitsumaniac wrote:Had in my previous FTO, and trust me it does the job. Probably will get one for current car as well. TBH this threas has remined me about these boxes again.
Bernard wrote:Those sealed units (while more effective) make me nervous.
You have no break in connection from outside the car right into the engine.
If the inlet is positioned low down, which it normally is, and you hit a flood or any depth of standing water it's sucked into your engine.
I know it's not likely to happen but still...
