I've never had to replace the rear plugs on the V6 before, it was something I had wanted to do for a long time more so to understand the process than anything else. Heres a few pics:
Muad_dib77 wrote:The Difference for a set of Denso Platinums vs non platinums seems to be 35-45 euros depending on supplier..
Q. What makes Iridium better?
A. Until recently, platinum was considered the best material to use on the top of an electrode because of its durability. However, Iridium is 6 times harder, 8 times stronger, and has a melting point 1200 degrees higher than platinum. Put that into a harsh environment such as an engine piston chamber, and you have a spark plug that can resist wear much better than platinum. Additionally, the DENSO Iridium Power alloy is so durable; it allowed our engineers to produce the world’s smallest center electrode (.4mm) which reduces the voltage requirements, concentrating its sparking power. Also, its smaller size, combined with the tapered U-Groove ground electrode, allows more room for the flame kernel to develop and produce a more efficient combustion.
gfalls wrote:Blah blah blah... But does it ACTUALLY make any difference, or are they just charging higher prices![]()
CJ wrote:gfalls wrote:Blah blah blah... But does it ACTUALLY make any difference, or are they just charging higher prices![]()
They produce a cleaner spark for longer so you should see marginal perf increases and better fuel economy over time. I know that MfFTO runs Iridiums and speaks highly of them, they're the plug of choice for a lot of Jap performance enthusiasts.
belfastman wrote:CJ................seeing you done the rear plugs yourself,how long did it take you to do?.............
Kace wrote:CJ - do you need any special tools to change the front plugs ? How long did this take you
