Hey all-
I've been having very similar problems for a few weeks now.
First off the car kept cutting out on idle, then it started idling at over 2k.
Took the car to a reputable mechanic, he appeared to fix it but 20 mins
later it started reving high again.
Decided to take the car to Mitsubishi, like before they appeared to fix the problem but after a couple of hours it started overreving again.
The Mitsubishi mechanic did suggest that the Throttle Housing needed to be replaced.
So far my problem seems to be exactly the same as the problem that all of you were having.
But on top of this the engine has started hunting? while idling but also when actually driving.
High speeds are ok but when going slow the revs will start kicking up.
Does this suggest that the problem goes further than the stepper motor or could this be all part of the problem.
Any help would be appreciated.
