fto alternator removal
Postby dtcarry » Sun Oct 05, 2008 6:49 pm
hi there new member Have v6fto auto and have a problem with the alternator could someone tell me how to remove it as there is very little room I have all the bolts and wiring removed there does not seem to be enough room to remove it
dtcarry
Postby CJ » Mon Oct 06, 2008 9:05 am
Most people go in through the drivers side wheel arch, there seems to be more room that way.
Welcome to the forum by the way...
Postby dtcarry » Mon Oct 06, 2008 10:07 pm
trying that way at the moment but the drive & steering rack seem to be in the way. is there anything else that i should remove
dtcarry
Postby Sebastian » Mon Oct 06, 2008 10:16 pm
i'm having the same problem . seems like it's nearly impossible to take out .
rory any suggestions??
Postby colm_mcm » Mon Oct 06, 2008 10:26 pm
yup, it's very tight, almost seems like the exhaust manifold has to come off to get it out.
Postby Sebastian » Mon Oct 06, 2008 10:29 pm
colm_mcm wrote:yup, it's very tight, almost seems like the exhaust manifold has to come off to get it out.
that's my concern . fre%kin bolts
Postby Syn » Mon Oct 06, 2008 11:38 pm
If ur doing it from above manifold needs 2come off.if ur doing it from below top mount on suspension strut needs to be loosened to lower enough to get it out
Syn
Postby ftoandy » Tue Oct 07, 2008 1:05 am
I done mine a few months ago and after alot of pulling i done extactly what syn has said.
ftoandy
Super unleaded
Super unleaded
Postby johnny » Tue Oct 07, 2008 10:00 am
I did it from below on a GPX....took the manifold and downpipe off....still tough to wiggle in and out but not too bad.
johnny
Alternator removal
Postby dtcarry » Wed Oct 08, 2008 8:47 pm
Sounds like a good idea to drop the strut I was going to loosen the top engine mounting and jack it up a bit .But the strut sounds better nice one will have a battle with it later on . thanks
dtcarry
Postby mark » Fri Oct 17, 2008 5:14 pm
Pop the drive shaft out, it's a bit of work but not too hard. Search the forum here as I have more detailed info from a while back. Just have some gearbox oil handy depending on the angle that its jacked at as it could leak out. Might be an idea to change the oil anyway!
mark
