Glass Antenna problem
Postby colm_mcm » Thu May 22, 2008 7:55 pm
My car had a Jap spec Pioneer Carrozzeria double DIN unit in it, I have since replaced with a Sony headunit, bought the Autoleads adaptor, and it plugged straight in and worked.
My problem is that I have no radio reception whatsoever. I'm now wondering if the Pioneer unit had an aerial amp in it. the aerial is built into the rear window
My last FTO had the same aerial setup, and I had no problem getting reception.
Any ideas. the hedunit is brand new, I might try another unit in it and see what happens.
Postby Bernard » Thu May 22, 2008 7:57 pm
Do you have a tinted rear window by any chance?
Postby colm_mcm » Thu May 22, 2008 8:09 pm
no I don't.
and Radio 1 worked fine on the Pioneer radio!
Postby steelroe » Thu May 22, 2008 10:31 pm
Is there a band expander in there that needs to be removed. Or remove the passanger rear plastic panel and make sure both wires of the aerial are connected
Postby colm_mcm » Thu May 22, 2008 10:45 pm
will try that,
that's great, if this fixes it that'll be 3 out of 3 queries solved this evening!
Users browsing this forum: No registered users and 9 guests
