thanks
ftomad wrote:are 215 48 18's too big for a gp VR does anyone tink or will the rub? ticking off getting them, maybe sum1 has had they and can tell me do they work please
thanks
Myfeckin FTO wrote:ftomad wrote:are 215 48 18's too big for a gp VR does anyone tink or will the rub? ticking off getting them, maybe sum1 has had they and can tell me do they work please
thanks
Presuming you mean 215/45 18 - then I would say they are well over spec and are quite likely to rub off the bottom of the damper - really depends on the offset of the rim. I know Dave on here ran a not too dissimilar rim and tyre combo but the correct size for an 18 inch rim would be a 35 rather than a 45 profile though you'd likely get away with a 40 profile ok.
Personally I wouldn't bother with 18's on an FTO - I found the ideal size for a looks /weight/performance/ride/handling combination to be a 215/45 17inch rim - slightly over spec diameter but looks well/handles and rides well. And you'll be able to spend the money saved on better quality tyres.
colm_mcm wrote:I've 225/40R18's and lowered suspension on mine, no major scrubbing issues. you need to modify or remove the wing liners and do some "work" on the inner wing to make it work.
I'd recommend 17's instead though
Myfeckin FTO wrote:I would say to stick with 40 profiles and use spacers if the rims don't have the neccessary offset. A 35 profile on a 215 tyre is too little meat for Irish roads.
For looks its not that important to have an 18 inch rim - nice 17's with a 45 profile on lowered suspension will look just as good - as long as they reduce the gap between arch and wheel then thats the main thing:
Its more about lowering than rim size tbh - CJs lowered on 17's - Mustangs running 17's on standard: -
ftomad wrote:colm_mcm wrote:depends on if you're going with 215/35 or 225/40 tyres
thanks for all the help lads, if i went for a 215/35 i dont have to do anythin but ye reckon it wont work
so how bout the 215 40 profile
Myfeckin FTO wrote:However 18 inch rims will only look good if you have them on lowered suspension - otherwise it will look like you're driving a 4 x 4. This will further increase your tyres scrubbing the arches unless you pin back the arches and perhaps use spacers if you have a rim with a higher than 34 offset. Rim and tyre sidewall design will also have an influence on how much the tyres will scrub.
