Stephen wrote:Hi Lads,
Has anyone ever had to have there CB Joints (I Think) replaced. I have been getting a kinda knocking noise from my front wheels and a friend of mine says he had this problem with his lancer and that he got these things replaced and that sorted it!! If you think this maybe the problem any ideas wee to get them done around dublin and a rough price.
Cheers Lads,
Stephen
Hi Stephen
They're actually called CV (constant velocity) joints. Get into an empty car park and run the car around in circles with a full lock on the steering, swap direction and then do the same with the steering orientated in the opposite direction. If you hear a constant knocking noise on one side (which is usually the case) then the CV joint has seized. As regards a replacement, I'm unsure, I'd say that a CV joint off a Glanat GSi might do the job, I'll fire a mail off to Rory to see if he can help.
