handbrake cables
handbrake cables
Postby belfastman » Fri May 20, 2011 5:14 pm
Failed MOT AGAIN ON THE HANDBRAKE..........12% BRAKE PROFORMANCE EFFICIENCY...................any one a link new brake cables i can buy? i will need both cables won't i?
belfastman
Re: handbrake cables
Postby Sebastian » Fri May 20, 2011 5:26 pm
have you heard of Camskill ?
Postby belfastman » Fri May 20, 2011 6:06 pm
seb, i would need both cables?
belfastman
Postby Sebastian » Fri May 20, 2011 6:45 pm
Yes, they are not expensive and easy to change mate
http://camskill.co.uk/products.php?plid=m3b0s8p508
http://camskill.co.uk/products.php?plid=m3b0s8p509
under 50 quid .
Make sure they are to blaim and not a stuck caliper or bad brake pads.
Actually it will be a super opportunity to clean the calipers and put new pads on(they are only a tenner - same source )
good luck
Postby belfastman » Fri May 20, 2011 8:19 pm
seb. i had to change rear caliper for refurb one and i put in new pads.The only other thing that might be wrong if it is not the brake cables could be the discs. I will try the cables first,hopefully that my baby will pass MOT.........wHEN THE INSPECTOR CHECKED MY HANDBRAKE,it was pointed to the ceiling instead of the 4 clicks allowed for pass......
belfastman
Postby colm_mcm » Fri May 20, 2011 10:25 pm
Surely rear brake performance would be bad if there was a problem with the pads or discs?
Postby CJ » Sat May 21, 2011 9:40 am
belfastman wrote:swHEN THE INSPECTOR CHECKED MY HANDBRAKE,it was pointed to the ceiling instead of the 4 clicks allowed for pass......
Have you tried tightening the cable? Nut is underneath the cup holder.
Postby belfastman » Fri Jun 10, 2011 5:58 pm
Passed MOT today...happy days...5 weeks off road waiting for car to be sorted.... :D
belfastman
