Bad squeaking in engine
Postby sinlessgunner » Thu Mar 20, 2008 12:42 pm
Jesus I seem to do absolutely nothing but ask questions here ha!
Ok this has happened a few times after heavy rain, I start the car in the morning and this horrible noise comes from the engine. I can't figure out what it is. I know the fanbelt needs a slight adjustment but I don't think it's that. Once the car is running for a bit it stops making this noise. It sounds like a wet belt I think, I don't know. I can't really describe the sound but it's more than squeaking. Also can I tighten the fan belt when the car is running or should I turn it off each time?
sinlessgunner
Re: Bad squeaking in engine
Postby jpsautostyling » Thu Mar 20, 2008 2:15 pm
sinlessgunner wrote:Also can I tighten the fan belt when the car is running or should I turn it off each time?
you do that mate and it will rip your hand clean off turn it off then tighten it then see if the squek goes away.
jpsautostyling
Octane king
Octane king
Postby sinlessgunner » Thu Mar 20, 2008 3:10 pm
Good that's what I thought but said I'd ask all the same...how much can i turn the screw safely? I don't want to snap it!
sinlessgunner
Postby jpsautostyling » Thu Mar 20, 2008 3:11 pm
id do a quarter of a turn and keep checkin after each turn.
jpsautostyling
Octane king
Octane king
Postby sinlessgunner » Thu Mar 20, 2008 3:16 pm
Cool thanks!
sinlessgunner
Postby gt94 » Fri Mar 21, 2008 12:53 am
The next time it happens turn off the aircon and see does it stop,happens in my gpx also when it rains and on a frosty night think its the belt
gt94
Postby Myfeckin FTO » Fri Mar 21, 2008 5:48 am
The FTO belts are very exposed and are easy to get damp.
For a quick fix (presuming they are tightened ok etc) just sprinkle some talcum powder onto the belts while running (keep fingers away).
Postby CJ » Fri Mar 21, 2008 2:53 pm
One of the belt tensioners could also be worn, re-tension the belts for a start and take it from there.
