need some help with lights
Postby johntony » Thu Apr 17, 2008 5:20 pm
any ideas how to fix or were i would get something to fit the last owner drilled the bumper himself and put in side repeaters only thing is they are 50mm and the hole is 50mm
johntony
Postby Bernard » Thu Apr 17, 2008 6:36 pm
How about fitting something like this instead?
A little extra cold air is always good :wink:
http://www.hostileperformance.co.uk/HPitemdetail.php?v=FTO&vm=Mitsubishi&m=POWERTEC&id=PTCOLDAIRFEEDS
Postby Dragonheart » Thu Apr 17, 2008 6:42 pm
Would cover up the hole nicely and look like it was totally intentional.
Postby colm_mcm » Thu Apr 17, 2008 7:14 pm
on both sides?
Postby Bernard » Thu Apr 17, 2008 7:18 pm
colm_mcm wrote:on both sides?
Sure why not? Fill the holes wouldn't it?
Postby Dragonheart » Thu Apr 17, 2008 7:27 pm
Might as well take the headlights out and put some in there too.
Christ that reminds me! I was on site last year and there was an Evo in the car park, had what looked like an exhaust coming out just behind the front wheel arch. I presume it was an exhaust cause there was a black smoke trail up the side of the front panel and along the door a bit! Anyone seen this before? Seems a bit mad if you ask me!
Oh, you could alwaya fill those holes by fixing something behind them and filling with a plastic resin I presume could you?
Postby crayzidane » Thu Apr 17, 2008 8:10 pm
Yea its called a screamer pipe, often used on cars running huge power,
when the rpm reaches a pre determined rev a valve in the exhaust system opens, so it doesnt have to travel to the back of the car to exit and go through muffler etc, hence called a SCREAMER pipe. Seen this in TOTB a few years ago,
And yes I would think a cold air feed would look awesome
crayzidane
Postby Dragonheart » Thu Apr 17, 2008 8:37 pm
Ah, so it sort of like an external dump valve but for the exhaust instead of the turbo. Made a sh1t of his white paint though!
Postby johntony » Thu Apr 17, 2008 8:42 pm
do you know what diameter the cold air intakes are cos the holes are fairly close to the original spots so i only really have 50mm to play with
johntony
Postby crayzidane » Thu Apr 17, 2008 9:09 pm
I'd rather be hated for what I am,
than loved for what Im not.
crayzidane
