by mivecmad27 » Mon Dec 06, 2010 12:54 pm
are any of the pipes collapsing? is carpet in the footwels wet?if not sounds like an airlock in the cooling system,easiest way is to jack up the font of the car so the rad cap is nice and high(secure with axle stands obviously)take rad cap off,make sure the engine is cool first,bring the engine to normal operating temp,get someone to keep your revs at about 2000rpm while you pump the rad hose by hand,this should help force the trapped air out of your cooling system(you'll see the bubbles),this should allow the water flow through your heater matrix and give you heat and alolow your fan to kick in>
