Page 1 of 1
Phone Cuts off Internet
Posted:
Thu Mar 12, 2009 10:40 am
by steelroe
Maybe someone on here has a similar problem to this.
Whenever I answer the landline it causes the green internet light on my router to turn red and internet will not function. Once I hang up the internet returns after a couple of seconds.
Probably some setting in the router needs to be changed.
Posted:
Thu Mar 12, 2009 10:52 am
by adrian
Have you an ADSL splitter to split your phone and broadband signal in place?
Posted:
Thu Mar 12, 2009 10:58 am
by steelroe
Sorry for my ignorance Adrian but are you referring to the DSL filter, if so yes I have one connected to the phone connection to the router. The phone is plugged in to a phone socket in a diff room. Maybe I need a filter with the phone too ????
Posted:
Thu Mar 12, 2009 12:21 pm
by CJ
Install the filter at the jack closest to the router, position is important. More info:
http://www.ehow.com/how_2210245_install ... phone.html
Posted:
Thu Mar 12, 2009 12:49 pm
by finers
steelroe wrote:Sorry for my ignorance Adrian but are you referring to the DSL filter, if so yes I have one connected to the phone connection to the router. The phone is plugged in to a phone socket in a diff room. Maybe I need a filter with the phone too ????
Yup each phone needs a filter Rory;)
Posted:
Thu Mar 12, 2009 1:35 pm
by steelroe
Sorted I had a spare filtyer and plugged it into the other phone socket and problem solved. Should have realised this earlier as it only started happening when I moved the phone from the Router filter to its own phone outlet.
Next question are these filters router specific or will any dsl filter do. I am going to try and wire the filter into the back of the phone outlet as having a filter hanging from every oultet does not look great.
Posted:
Thu Mar 12, 2009 1:38 pm
by Baldrick
Filters are not router specific. Any one will do.
