HID Installation
HID Installation
Postby southerncomfort » Sun Jan 27, 2008 1:46 am
Hi Guys,
Just bought a set of HID's from the link below and the kit arrived without instructions. Are these straight forward to Install or have I bought a dodgy set?
http://www.rb-performance.co.uk/catalog ... ucts_id/37
If anybody has an installation guide or instructions for installing these it would be appreciated.
southerncomfort
Postby colm_mcm » Sun Jan 27, 2008 12:36 pm
Look here: http://www.fto-ireland.com/forum/phpBB2 ... c&start=25
Seems expensive if they're just regular Ebay type HID's
BEFORE YOU PLUG ANYTHING IN: make sure the earth and live wire on the FTO plug matches that on the HID kit, I thing the FTO's plug is wired backwards.
Fitting is very simple, the plug that goes into your existing healight plugs into the ballast (box) the ballast will have another lead coming from it to the HID bulb. there's no other wiring required.
Here's a picture of my wiring diagram, presume yours is the same
Postby kevinod » Sun Jan 27, 2008 11:23 pm
Ya, I found with mine that the wiring on the set as it came were reversed compared to what the FTO has, but once I sussed that, and reversed the wiring I was sorted.
Postby Kace » Wed May 07, 2008 3:15 pm
In the picture shown above - can anyone confirm what the rubber grommit on the wiring (a few inches from the bulb) is for and whether this needs to form part of the install ?
Thanks
Kace
Postby CJ » Wed May 07, 2008 3:30 pm
Kace wrote:In the picture shown above - can anyone confirm what the rubber grommit on the wiring (a few inches from the bulb) is for and whether this needs to form part of the install ?
As I understand it, its a means of keeping the cabling together, thats all.
Postby colm_mcm » Wed May 07, 2008 3:43 pm
yup, it has no real use. I presume on some cars this would form a seal.
