Get-you-home tyre foam
Postby colm_mcm » Tue Oct 16, 2007 4:36 pm
What's the craic with leaving this stuff in your tyre, does it damage the rubber?
Postby Myfeckin FTO » Tue Oct 16, 2007 4:40 pm
Not really - you could just let it back out through the nozzle and refill with air while the puncture is being repaired. I haven't had to change a wheel in years thanks to these repair kits getting me to the nearest tyre place.
Postby colm_mcm » Tue Oct 16, 2007 5:16 pm
I found out that the spare wheel doesn't turn on my car, it's fouling the caliper. either the brakes are upgraded on the spare isn't the right one. can anyone post a picture of a proper FTO spare?
I used the foam last Saturday night as a last resort. haven't got around to fixing it yet.
Postby Muad_dib77 » Tue Oct 16, 2007 5:24 pm
It fouling your larger calipers on the front?
the spare should go on one of the rears..
what you'll need to do is move and alloy to the front (if you have a flat there) and use the spare crummy wheel on the back..
Postby colm_mcm » Tue Oct 16, 2007 5:38 pm
It's enough of a pain in the hole changing 1 tyre
Postby Muad_dib77 » Tue Oct 16, 2007 8:00 pm
lol - yeah but I'm guessing your brembos are wider than the standard brakes.. :-)
Postby colm_mcm » Tue Oct 16, 2007 8:05 pm
they're not even brembos!
Postby Muad_dib77 » Tue Oct 16, 2007 8:15 pm
huh?? I thought you had non-standard brakes on.. have you the original brakes on?
Postby colm_mcm » Tue Oct 16, 2007 8:20 pm
They have Mitsubishi written on them, and there's drilled and grooved discs. No idea whether they're standard or not. They're certainly a lot better than other FTO's I've driven
Postby Muad_dib77 » Tue Oct 16, 2007 8:23 pm
hmm... can you stick a picture in?
Postby colm_mcm » Tue Oct 16, 2007 8:29 pm
I've got my sensible car at home this evening, maybe I have one on file somewhere....
Postby colm_mcm » Tue Oct 16, 2007 8:35 pm
best one I can find
Postby CJ » Tue Oct 16, 2007 9:05 pm
Std GPX calipers.
Whats all this talk of the spacesaver not fitting the front? I'm sure I've used one up front a few times in the past...
Postby colm_mcm » Tue Oct 16, 2007 9:12 pm
It won't fit, that's the story. If my calipers are standard, that means my spare wheel isn't one for an FTO.
(anyone got a spare one?)
Postby Muad_dib77 » Tue Oct 16, 2007 9:22 pm
yeah the look like painted fto calipers ..odd..
my spare fits the front just fine..maybe you have one with a different offset...
Postby CJ » Tue Oct 16, 2007 9:46 pm
colm_mcm wrote:It won't fit, that's the story.
I was referring to this piece of mad talk:
Muad_dib77 wrote:the spare should go on one of the rears..
The spacesaver will fit on either the front or rear (with std calipers) without probs.
colm_mcm wrote:(anyone got a spare one?)
What as in an spare spare? :smt005 Steelroe will have one for sure...
Postby colm_mcm » Tue Oct 16, 2007 9:46 pm
either way I need a pic of a proper FTO spare, so I can compare how mine looks. All I know is its yellow and it fits the studs on the FTO.
Postby Muad_dib77 » Tue Oct 16, 2007 9:50 pm
Ah yes - it'll fit - but apparently - it's not best practise to have the spare on a driving wheel..
Postby Daz » Wed Oct 17, 2007 3:51 am
The standard egg yoke spare will fit the front of any standard FTO break set-up including gpx, the calipers ain't an issue, a recomendation i read once in a manual one time was, not to be driven on for more than 30 miles at a time and not above 50klm,
Daz
Postby colm_mcm » Wed Oct 17, 2007 10:06 am
I take it that my spare wheel is off something else so.
Thanks previous owner!
Postby Daz » Thu Oct 18, 2007 2:14 am
colm_mcm wrote:I take it that my spare wheel is off something else so.
I'm sure steelroe will have a few knocking about.
Daz...
Daz
