Handbrake Warning light stays ON
Postby Sebastian » Wed Nov 25, 2009 11:42 pm
Well , noticed this staring a few weeks back but i thought it's just the cold acting on the handbrake cables .
the light stays ON for about 20 mins in the mornings/evenings till the car is ''warm'' , then it turns itself OFF .
i've checked brakeflyuid levels , seem OK , the handbrake cables are not stuck .
Any other ''sensor'' conected to that light (or pads?)
any advice would be great!
Re: Handbrake Warning light stays ON
Postby CJ » Wed Nov 25, 2009 11:47 pm
Checked the pad levels? (Low pad material can trigger the light). Rear caliper seizure? Handbrake cable over tight?
Postby Kace » Wed Nov 25, 2009 11:47 pm
Simple one - the 'sticking' switch is under the cup holder in the middle console between the seats. A squirt of WD-40 will sort this issue.
K
