I assume that the LSD is a seperate unit and has it's own oil reservoir?
Nope, its part of the gearbox, the gearbox oil acts as a lubricant in this instance. IIRC, tip boxes with integrated LSDs should have the AFT changed that bit more regularly than non LSD equipped boxes.
Are you saying that in a tip box car the LSD is lubricated by the ATF dextrox III, etc. Whereas in a manual car it is lubicated by 75w/90, or 80W90.
Or is it a case that in the manual car the LSD is sperate from the gearbox?
