Low Idle: 3.88% allowed: 0.5%
High Idle: 7.24% allowed: 0.3%
Lambda: 0.806 allowed betwenn 0.97 and 1.03
HC 267 allowed: 200ppm or below
I know its bad, but how bad?
steelroe wrote:Your cat converter was removed when the aftermarket exhaust was fitted. You need a cat con and this may prove difficult to find as the Version R has a different Cat fitted compared to other models from memory.
Is this answer serious enough for you![]()
fatboyfat7 wrote:....provided there's a decat fitted, it is possible to fit a cat con to my aftermarket exhaust. And Colm thinks a GPX one (like Toms) will do the job despite the heat sensor but Rory isnt as sure... Correct?
