evo 5 engine and fto gearbox?
Postby colm_mcm » Mon Jul 12, 2010 10:29 pm
Would it fit?
The f-ies-to may be getting another 250 HP if it does. How long the ftos box would last is another matter
Re: evo 5 engine and fto gearbox?
Postby Dragonheart » Mon Jul 12, 2010 10:32 pm
Evo 4 fits doesn't it? Did I see someone with that done in Oz? If the gearbox can hold the power of a s/c I'd imagine it would manage an Evo engine. How hard would a 4wd conversion be seeing as its totally stripped anyway?
Postby colm_mcm » Mon Jul 12, 2010 11:24 pm
The engine's in the back so probably a bit difficult!
It's an additional 250hp on top of the standard gpx.
Postby Dragonheart » Mon Jul 12, 2010 11:54 pm
447hp with a car that light will be lethal! Where is it at in terms of being ready?
Postby escu_calin » Tue Jul 13, 2010 8:21 am
Dragonheart wrote:447hp with a car that light will be lethal! Where is it at in terms of being ready?
you need Caterpillar not 4x4 for that kinda power transfer :)) and a thick layer of lead, putting the weight up a ton or something:)
... and even so.. are these serious thoughts or you ppl are so extremely bored:) ?
escu_calin
Postby Bernard » Tue Jul 13, 2010 5:57 pm
Have a read here.
That kind of power is possible if you know what you're doing.
Postby Dragonheart » Tue Jul 13, 2010 6:24 pm
Is that D_Dans?? ...........oh actually.........wait...............
Serious yoke there though, even removing headlights for the optimum performance. :D
Postby colm_mcm » Tue Jul 13, 2010 11:23 pm
It's not anywhere near ready.
Just need to know about the compatability first
Postby witcher » Wed Jul 14, 2010 8:18 pm
wouldn't it be easier to use evo engine and gearbox with disabled rear drive?? this way you can save on LSD, cause at this level of power it is obligatory to install one, and it will cope with all this power better than fto box intended for 200 hp car.
witcher
