mivecrx wrote:http://www.ncts.ie/NCT%20Manual%20Revise%20May%202012.pdf Section 3, page 13 look at the note section note 9 that should explain I think. Best to ring the NCT and ask them to be 100%.
goz_83 wrote:I find that interesting, because a, b, or c did not apply. Where does it mention the EML? You did mention this in your pm as a reason. It would be common sense to abandon an emissions test if the exhaust has a leak, but you seem to have trouble grasping that fact. If there is a problem with the system, it cannot be tested.
I tend to check facts before calling someone a liar, but that's just me. No big deal I guess
I already told you it's no longer open for sale to you, so why would you even say you won't be viewing? Boggles the mind. I think this discussion is over. Best of luck in finding an fto. I am sure you will find a more honest seller than I.
As I said, I will now get the parts installed and retest the car. I'm sure it'll pass once the exhaust is sorted and the steering parts too.
mivecrx wrote:What did I lie about on here?
goz_83 wrote:EDIT: Come to think of it, I remember the car was in the emissions area for a while so he may have tested them, but cancelled the result when he found the leak.
mivecrx wrote:goz_83 wrote:EDIT: Come to think of it, I remember the car was in the emissions area for a while so he may have tested them, but cancelled the result when he found the leak.
But you said he heard the leak in 1st gear and didn't bother testing them? NOW YOU HAVE EDITED THAT SENTENCE FROM YOUR POST.
Maybe I was right not to trust you!
goz_83 wrote:The same guy who made private the youtube link which was here => http://www.youtube.com/watch?v=i3gT_nn3GYc until I pointed it out on a forum. Oh, and the same guy who asked me to race on public roads. That proof is in my inbox
You're a liar and you know it.
Street racing is not condoned on this forum. It's dangerous, reckless and illegal.
goz_83 wrote:Yeah. You must be a young chap. Read the first line of text referring to mods. But that won't be necessary. Most of the guys on here I am sure know I don't BS (that much)
goz_83 wrote:Was supposed to have a member of a forum (won't say which forum) view the fto today. I told him that I would let the car go for €1050, which is at a small loss considering what has gone into the car. I had my eye on another project and so I offered the car at a knock down price. I told him everything that was needed and have an nct fail sheet to show what it failed on. Retest would be €28 and he could have fit the parts himself. I also have the parts the car needs (driver side steering rack and inner tie rod end), except for the centre section of exhaust, which has a small hole in it.
The NCT tester did not test the emissions because there was a hole in the exhaust. This is what I was told when collecting the fail sheet. The tester was a decent guy and took the time to show me where the problems were. He even pointed out that I had missed some corrosion at the rear, which needed to be treated.
So the guy coming to view the car has the cheek to pm me to say he wouldn't be coming to see the car (that part is fine). His reason; Well apparently I am being dishonest with him, because there is supposedly only 2 reasons the nct centre will not check emissions. #1 Oil Light. #2 EML. Personally I figured there would be more reasons (including a hole in the exhaust). So, just to satisfy my curiosity; If there is a hole in the exhaust, will the nct test the emissions anyway?
To note: The oil light and eml work just fine and turn off when the engine is started, as normal. However, the airbag light does need to be turned off, because my brother in law had the wheel off and when he put it back on, the srs light came on. I find it insulting that someone can make stupid accusations based on what a mate of a mate said
brccrx wrote:goz_83 wrote:Was supposed to have a member of a forum (won't say which forum) view the fto today. I told him that I would let the car go for €1050, which is at a small loss considering what has gone into the car. I had my eye on another project and so I offered the car at a knock down price. I told him everything that was needed and have an nct fail sheet to show what it failed on. Retest would be €28 and he could have fit the parts himself. I also have the parts the car needs (driver side steering rack and inner tie rod end), except for the centre section of exhaust, which has a small hole in it.
The NCT center test the emission regardless the holes/holes in the exhaust to answer Your question (didnt read the whole tread, i say the rest would say te same even not reading the whole lot either
mivecrx wrote:Nice picture goz, what is it of? two cars driving on a dual carriage way it seems.
You're after accusing me of street racing with zero proof and I wan't all the post stating that removed! I'm sure the Mods will agree on that.
@brccrx Are you sure it's two cars? very hard make out
