shane wrote:Did you use a bleed kit?
No, but if you don't it can get messy, make sure you've plenty of newspaper and rags around.
shane wrote:If you don't have a bleed kit do you just disconnect the brake pipe from the caliper?
No, you unscrew the drainline from the caliper, it has a removable rubber cover over it, go take a look!
shane wrote:And do you not need someone to stand on the brake pedal to push the fluid out?
No, gravity does it for you
Its pretty straighforward once you get started...
