d_dan wrote:Who here feels the FTO chassis is a bit soft
d_dan wrote:you obviously havnt been in a Teg that somone has some work into making it nice and rigid.........
d_dan wrote:you obviously havnt been in a Teg that somone has some work into making it nice and rigid...............
d_dan wrote:hey Shane iv a lend of a tweesers if you wana pull whatever crawled up your ass back out.![]()
...............Sadly its dosnt seem like a passion of many of you here when Seb's idea for a modified/ performance section was done...
You would think that a section of the site designed to Technical Discussion Forum would be to discuss the pros and cons of ideas
d_dan wrote:You would think that a section of the site designed to Technical Discussion Forum would be to discuss the pros and cons of ideas :roll:
d_dan wrote:Sadly its dosnt seem like a passion of many of you here when Seb's idea for a modified/ performance section was done...
Dan, how the hell to you expect to get favourable replies to you posts when you make general sweeping comments like that which are insulting and also just not true. A lot of people here have TASTEFULLY modified their cars, to their own spec, so if they don't stack up to what you considered modified, tough $hit, but the least you could do is not insult people about it. And you go on about not wanting to talk about the money side of it, which is fair enough, but do the rest of us have to spend thousands before you consider it modified? Cop on!d_dan wrote:Sadly its dosnt seem like a passion of many of you here ..
Hi Dan I think if you do all you have listed here you will make the car too! rigid and thus making the car unpredictable at the limit. a roll cage well tide in to the chassis should go a long way to providing the strength your looking for. as for the ikea panel you'd be better off triangulating this area using alloy tubing bolted in place, better strength to weight ratio than steel plate. well impresed so far with your efforts keep up the good work, what kind of power do you hope to acheive?d_dan wrote:you obviously havnt been in a Teg that somone has some work into making it nice and rigid.
I for example
am having to look for some drastic measures to get the FTO as solid as i can.
Fitting a Roll cage,
Making arch braces,
Underbody strutbarces,
IKEA brace (flat pannel welded in the gap behind the rear seats)
Foaming the Chasis.
Myfeckin FTO wrote:d_dan wrote:you obviously havnt been in a Teg that somone has some work into making it nice and rigid.........
What the f*ck do you know about what I have and haven't driven?
colm_mcm wrote:I wouldn't say it's any worse than its competition (DC2 Integra, Fiat Coupe, Toyota Celica etc.)
d_dan wrote:.............In terms of power im looking for about 260 from my build
gary d wrote:..allways set your sights high if you get even halfway there your doin well.
gary d wrote:Don't be hatin on a playa....ll.
