On the flip side of the coin I found a brilliant Air Conditioning company called Auto Air in Meath. The engineer there, Brendan Kealy, was extremely knowledgeable, he ran a full pressure test to see if there was a leak in the system, repaired the condenser (Very, very expensive to buy from Mitsubishi), flushed the system and re-pressurised it with the Air Con fluid. The Climate Control is now as good as new for the exact same cost as the standard Air Con Top-Up. Good service above and beyond the call of duty.
A lot of cars are running on anti freeze instead of coolant
Can you please explain? Is this heater matrix directly connected to the engine cooling system? If so are you saying that people should be using a coolant instead of anti-freeze:?: I didn't know that there was such a thing as coolant (as apposed to antifreeze). Excuse my ignorance here, as I really know nothing about it, but now I'm afraid........
Mustang
