Removing the Torque Converter?
Postby Aido C » Thu Sep 10, 2009 8:02 pm
Does anyone know how do I remove the torque converter? (I already have the box off). I just can't see any nuts or bolts.
Thanks.
Aido C
Have you seen my FTO tattoo?
Re: Removing the Torque Converter?
Postby Bernard » Thu Sep 10, 2009 8:57 pm
Not sure if it's any help, but some of the pics on this thread might give you a clue.
http://www.fto-ireland.com/forum/viewtopic.php?f=1&t=8144&p=58357
Postby Gerry » Thu Sep 10, 2009 9:17 pm
Hi,
There are four bolts holding the TC in place to the engine, they are located at the base of the TC(engine side).
They have a short head, if you look at the engine side of the TC you shoud see one of them, note you
will have to rotate the engine to find the next one and so on.
Hope this helps.
Gerry
Postby steelroe » Thu Sep 10, 2009 11:00 pm
The plate holding the TC is in the shape of a cross, i.e 4 bolting corners. If you look diresctly behind the TC you will see the heads of the bolts (very low in height. You will need a 17mm open ended spanner.
You will also have to rotate the tc to get at all the bolts in turn
Postby Aido C » Fri Sep 11, 2009 1:11 am
Thanks lads. Great help:)
Aido C
